Blowing up affine hybrid systems, 2004 43rd IEEE Conference on Decision and Control (CDC) (IEEE Cat. No.04CH37601), pp.473-478, 2004. ,
DOI : 10.1109/CDC.2004.1428675
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.116.4933
Investigation of the Degeneracy Phenomenon of the Maximum Principle for Optimal Control Problems with State Constraints, SIAM Journal on Control and Optimization, vol.35, issue.3, pp.930-952, 1997. ,
DOI : 10.1137/S036301299426996X
Stabilization of DAEs and invariant manifolds, Numerische Mathematik, vol.67, issue.2, pp.131-149, 1994. ,
DOI : 10.1007/s002110050020
Convex Control Systems and Convex Optimal Control Problems With Constraints, IEEE Transactions on Automatic Control, vol.53, issue.4, pp.993-998, 2008. ,
DOI : 10.1109/TAC.2008.919848
Optimal control of impulsive hybrid systems, Nonlinear Analysis: Hybrid Systems, vol.2, issue.4, pp.1089-1097, 2008. ,
DOI : 10.1016/j.nahs.2008.09.003
Approximability of nonlinear affine control systems, Nonlinear Analysis: Hybrid Systems, vol.5, issue.2, pp.275-288, 2011. ,
DOI : 10.1016/j.nahs.2010.07.005
A proximal point approach to optimal control of affine switched systems, pp.61-81, 2012. ,
On the set-valued approach to optimal control of sliding mode processes, Journal of the Franklin Institute, vol.349, issue.4, pp.1323-1336, 2012. ,
DOI : 10.1016/j.jfranklin.2011.07.002
On the geometric aspects of the invariant ellipsoid method: Application to the robust control design, IEEE Conference on Decision and Control and European Control Conference, pp.1353-1358, 2011. ,
DOI : 10.1109/CDC.2011.6161180
Modern Sliding Mode Control Theory, Lecture Notes in Control and Information Sciences, vol.375, 2008. ,
DOI : 10.1007/978-3-540-79016-7
Sliding mode regulator as solution to optimal control problem, 2008 47th IEEE Conference on Decision and Control, pp.2184-2189, 2008. ,
DOI : 10.1109/CDC.2008.4739114
Optimal Control Theory, 1974. ,
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Discontinuous Control Systems Frequency-Domain Analysis and Design, 2009. ,
On the Transfer Properties of the “Generalized Sub-Optimal” Second-Order Sliding Mode Control Algorithm, IEEE Transactions on Automatic Control, vol.54, issue.2, pp.399-403, 2009. ,
DOI : 10.1109/TAC.2008.2008361
Singular Trajectories and their Role in Control Theory, 2003. ,
Multivalued Differential equations, de Gruyter, 1992. ,
Infinite-Dimensional Optimization and Control Theory, 1999. ,
DOI : 10.1017/CBO9780511574795
Nondegenerate Necessary Conditions for Nonconvex Optimal Control Problems with State Constraints, Journal of Mathematical Analysis and Applications, vol.233, issue.1, pp.116-129, 1999. ,
DOI : 10.1006/jmaa.1999.6270
A Sub-Optimal Second Order Sliding Mode Controller for Systems With Saturating Actuators, IEEE Transactions on Automatic Control, vol.54, issue.5, pp.1082-1087, 2009. ,
DOI : 10.1109/TAC.2008.2010992
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
High-order sliding-mode observation for linear systems with unknown inputs, Nonlinear Analysis: Hybrid Systems, pp.189-205, 2011. ,
Quasi-continuous high order sliding modes controllers applied to glucoseinsulin regulatory system models, Proceedings of the 47th IEEE Conference on Decision and Control, pp.2208-2213, 2008. ,
Principles of Optimal Control Theory, 1978. ,
DOI : 10.1007/978-1-4684-7398-8
Measurable relations, Fundamenta Mathematicae, vol.87, pp.53-72, 1975. ,
Finite-time stabilization and stabilizability of a class of controllable systems, Systems & Control Letters, vol.46, issue.4, pp.231-236, 2002. ,
DOI : 10.1016/S0167-6911(02)00119-6
Universal single-input-single-output (SISO) sliding-mode controllers with finite-time convergence, IEEE Transactions on Automatic Control, vol.46, issue.9, pp.1447-1451, 2001. ,
DOI : 10.1109/9.948475
Robust sliding mode control for uncertain linear discrete systems independent of time-delay, International Journal of Innovative Computing Information and Control, vol.7, pp.869-881, 2011. ,
Lyapunov-based approach for finite time stability and stabilization, Proceedings of the 44th IEEE Conference on Decision and Control, pp.4742-4747, 2005. ,
DOI : 10.1109/CDC.2005.1582911
Discontinuous Systems: Lyapunov Analysis and Robust Synthesis under Uncertainty Conditions, 2008. ,
A calculus for computing Filippov's differential inclusion with application to the variable structure control of robot manipulators, IEEE Transactions on Circuits and Systems, vol.34, issue.1, pp.73-82, 1987. ,
DOI : 10.1109/TCS.1987.1086038
Reaching Time Estimation for “Super-Twisting” Second Order Sliding Mode Controller via Lyapunov Function Designing, IEEE Transactions on Automatic Control, vol.54, issue.8, pp.1951-1955, 2009. ,
DOI : 10.1109/TAC.2009.2023781
Advanced Mathematical Tools for Automatic Control Engineers, 2008. ,
On the Hybrid Optimal Control Problem: Theory and Algorithms, IEEE Transactions on Automatic Control, vol.52, issue.9, pp.1587-1603, 2007. ,
DOI : 10.1109/TAC.2007.904451
Sliding Modes in Control and Optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Adaptive super-tvist control with minimal chattering effect, Proceedings of the 2011 Conference on Decision and Control, 2011. ,
State estimation and sliding mode control of Markovian jump singular systems, IEEE Transactions on Automatic Control, vol.55, pp.1213-1219, 2010. ,
Adaptive variable structure state estimation for uncertain systems with persistently bounded disturbances, International Journal of Robust and Nonlinear Control, vol.8, issue.4, pp.2003-2015, 2010. ,
DOI : 10.1002/rnc.1567
Sliding Mode Control for Linear Systems with Time-Varying Input and State Delays, Circuits, Systems, and Signal Processing, vol.2, issue.1, pp.629-641, 2011. ,
DOI : 10.1007/s00034-010-9237-x
Sliding mode control strategies for the hyperchaotic MCK system, ICIC Express Letters, vol.3, pp.283-288, 2009. ,
Direct adaptive neural control with sliding mode method for a class of uncertain switched nonlinear systems, International Journal of Innovative Computing, Information and Control, vol.6, pp.5609-5618, 2010. ,
The sliding mode variable structure control based on composite reaching law of active magnetic bearing, ICIC Express Letters, vol.2, pp.59-63, 2008. ,
