Idealized models for FEA derived from generative modeling processes based on extrusion primitives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shape idealization transformations are very common when adapting a CAD component to FEA requirements. Here, an idealization approach is proposed that is based on generative shape processes used to decompose an initial B-Rep object, i.e. extrusion processes. The corresponding primitives form the basis of candidate sub domains for idealization and their connections conveyed through the generative processes they belong to, bring robustness to set up the appropriate connections between idealized sub domains. Taking advantage of an existing construction tree as available in a CAD software does not help much because it may be complicated to use it for idealization processes. Using generative processes attached to an object that are no longer reduced to a single construction tree but to a graph containing all non trivial construction trees, is more useful for the engineer to evaluate variants of idealization. From this automated decomposition, each primitive is analyzed to define whether it can idealized or not. Subsequently, geometric interfaces between primitives are taken into account to determine more precisely the idealizable sub domains and their contours when primitives are incrementally merged to come back to the initial object.
IMR22_-_15_-_ideal_decomp_gen_proc_fea.pdf (3.85 Mo) Télécharger le fichier
hal-00922916 , version 1 (31-12-2013)
hal-00922916 , version 2 (10-10-2014)
Flavien Boussuge, Jean-Claude Léon, Stefanie Hahmann, Lionel Fine. Idealized models for FEA derived from generative modeling processes based on extrusion primitives. 22nd International Meshing Roundtable, Oct 2013, Orlando, United States. pp.127-145, ⟨10.1007/978-3-319-02335-9_8⟩. ⟨hal-00922916v1⟩
548 Consultations
533 Téléchargements
