Multiple Change-Point Estimation With a Total Variation Penalty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the American Statistical Association Année : 2010
We propose a new approach for dealing with the estimation of the location of change-points in one-dimensional piecewise constant signals observed in white noise. Our approach consists in reframing this task in a variable selection context. We use a penalized least-square criterion with a ℓ1-type penalty for this purpose. We explain how to implement this method in practice by using the LARS / LASSO algorithm. We then prove that, in an appropriate asymptotic framework, this method provides consistent estimators of the change points with an almost optimal rate. We finally provide an improved practical version of this method by combining it with a reduced version of the dynamic programming algorithm and we successfully compare it with classical methods.
hal-00923474 , version 1 (02-01-2014)
Zaid Harchaoui, Céline Lévy-Leduc. Multiple Change-Point Estimation With a Total Variation Penalty. Journal of the American Statistical Association, 2010, 105 (492), pp.1480-1493. ⟨10.1198/jasa.2010.tm09181⟩. ⟨hal-00923474⟩
524 Consultations
0 Téléchargements
