Bounds on capacity and minimum energy-per-bit for AWGN relay channels, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1545-1561, 2006. ,
DOI : 10.1109/TIT.2006.871579
Bounds on Achievable Rates for General Multi-terminal Networks with Practical Constraints, Proc. Int. Conf. Information Processing Sensor Networks, pp.146-161, 2003. ,
DOI : 10.1007/3-540-36978-3_10
Capacity Bounds and Power Allocation for Wireless Relay Channels, IEEE Transactions on Information Theory, vol.51, issue.6, pp.2020-2040, 2005. ,
DOI : 10.1109/TIT.2005.847703
Cooperative communications with relay-selection: when to cooperate and whom to cooperate with?, IEEE Transactions on Wireless Communications, vol.7, issue.7, pp.2814-2827, 2008. ,
DOI : 10.1109/TWC.2008.070176
Cooperative Communications with Outage-Optimal Opportunistic Relaying, IEEE Transactions on Wireless Communications, vol.6, issue.9, pp.3450-3460, 2007. ,
DOI : 10.1109/TWC.2007.06020050
Selective Cooperative Relaying over Time-Varying Channels, IEEE Transactions on Communications, vol.58, issue.8, pp.2402-2412, 2010. ,
DOI : 10.1109/TCOMM.2010.062310.090065
URL : http://arxiv.org/abs/0905.0564
Cooperative Strategies and Capacity Theorems for Relay Networks, IEEE Transactions on Information Theory, vol.51, issue.9, pp.3037-3063, 2005. ,
DOI : 10.1109/TIT.2005.853304
Power allocation in relay channels under a global power constraint using virtual nodes, 2013 IEEE 24th Annual International Symposium on Personal, Indoor, and Mobile Radio Communications (PIMRC), 2013. ,
DOI : 10.1109/PIMRC.2013.6666274
URL : https://hal.archives-ouvertes.fr/hal-00923653
Full mesh channel measurements on body area networks under walking scenarios, Proc. European Conf. Antennas Propagation, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00923651
High-SNR Analysis of Opportunistic Relaying Based on the Maximum Harmonic Mean Selection Criterion, IEEE Signal Processing Letters, vol.17, issue.8, pp.719-722, 2010. ,
DOI : 10.1109/LSP.2010.2051946
Statistical channel knowledge-based optimum power allocation for relaying protocols in the high SNR regime, IEEE Journal on Selected Areas in Communications, vol.25, issue.2, pp.292-305, 2007. ,
DOI : 10.1109/JSAC.2007.070206
