Processing XML queries and updates on map/reduce clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this demo we will showcase a research prototype for processing queries and updates on large XML documents. The prototype is based on the idea of statically and dynamically partitioning the input document, so to distribute the computing load among the machines of a Map/Reduce cluster. Attendees will be able to run predefined queries and updates on documents conforming to the XMark schema, as well as to submit their own queries and updates.
Fichier non déposé
hal-00923695 , version 1 (03-01-2014)
  • HAL Id : hal-00923695 , version 1
Nicole Bidoit, Dario Colazzo, Noor Malla, Federico Ulliana, Maurizio Nolé, et al.. Processing XML queries and updates on map/reduce clusters. International Conference on Extending Database Technology, Mar 2013, Genova, Italy. ⟨hal-00923695⟩
118 Consultations
0 Téléchargements
