A Passivity-Based Controller for coordination of converters in a Fuel Cell System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Control Engineering Practice Année : 2013
The problem of converters coordination of a fuel cell system involving a hydrogen fuel cell with supercapacitors for applications with high instantaneous dynamic power is addressed in this paper. The problem is solved by using a non-linear controller based on passivity. The controller design is based on the interconnection and damping assignment approach, where the proof of the local system stability of the whole closed-loop system is shown. Simulation and experimental results on a reduced scale system prove the feasibility of the proposed approach for a real electrical vehicle.
Automatique
Fuel_Cell_PBC_v2.pdf (1.29 Mo) Télécharger le fichier
hal-00923716 , version 1 (03-01-2014)
hal-00923716 , version 2 (02-03-2019)
M. Hiliaret, Malek Ghanes, O. Béthoux, Jean-Pierre Barbot, Dorothée Normand-Cyrot. A Passivity-Based Controller for coordination of converters in a Fuel Cell System. Control Engineering Practice, 2013, 21 (8), pp.1097-1109. ⟨10.1109/TVT.2013.2246202⟩. ⟨hal-00923716v1⟩
486 Consultations
1115 Téléchargements
