Diagnostic and fault tolerant control, 2003. ,
Bibliographical review on reconfigurable fault-tolerant control systems, Annual Reviews in Control, vol.32, issue.2, pp.229-252, 2008. ,
DOI : 10.1016/j.arcontrol.2008.03.008
Sensor fault detection and isolation for nonlinear systems based on a sliding mode observer, International Journal of Adaptive Control and Signal Processing, vol.34, issue.8-9, pp.657-673, 2007. ,
DOI : 10.1002/acs.967
Parity space-based fault detection for Markovian jump systems, International Journal of Systems Science, vol.3, issue.4, pp.421-428, 2009. ,
DOI : 10.1049/ip-cta:20045085
Nonlinear system fault diagnosis based on adaptive estimation, Automatica, vol.40, issue.7, pp.1181-1193, 2004. ,
DOI : 10.1016/j.automatica.2004.02.018
Decentralized Fault Diagnosis of Large-Scale Processes Using Multiblock Kernel Partial Least Squares, IEEE Transactions on Industrial Informatics, vol.6, issue.1, pp.3-10, 2010. ,
DOI : 10.1109/TII.2009.2033181
Modeling and Monitoring of Dynamic Processes, IEEE Transactions on Neural Networks and Learning Systems, vol.23, issue.2, pp.277-284, 2012. ,
DOI : 10.1109/TNNLS.2011.2179669
Two fault detection and isolation schemes for robot manipulators using soft computing techniques, Applied Soft Computing, vol.10, issue.1, pp.125-134, 2010. ,
DOI : 10.1016/j.asoc.2009.06.011
Fault-tolerant control in variable speed drives: a survey, IET Electric Power Applications, pp.121-134, 2008. ,
DOI : 10.1049/iet-epa:20070203
Diagnosis by parameter estimation of stator and rotor faults occurring in induction machines, IEEE Transactions on Industrial Electronics, vol.53, issue.3, pp.963-973, 2006. ,
DOI : 10.1109/TIE.2006.874258
On-line broken bars detection diagnosis by parameters estimation, 13th European Conference on Power Electronics and Applications, 2009. ,
Detection of broken rotor bars in induction motors using state and parameter estimation, IEEE Transactions on Industry Applications, vol.28, issue.3, pp.702-709, 1992. ,
DOI : 10.1109/28.137460
Detection of broken rotor bars in induction motors using nonlinear Kalman filters A highresolution frequency estimation method for threephase induction machine fault detection, ISA Transactions IEEE Transactions on Industrial Electronics, vol.49, issue.54, pp.189-195, 2007. ,
Detection of broken rotor bars in three-phase squirrel-cage induction motor using fast Fourier transform, 10th International Symposium , Topical Problems in the Field of Electrical and Power Engineering, pp.52-56, 2011. ,
Recent developments of induction motor drives fault diagnosis using AI techniques, IEEE Transactions on Industrial Electronics, vol.47, issue.5, pp.994-1004, 2000. ,
DOI : 10.1109/41.873207
Backstepping fault tolerant control based on second order sliding mode observer: Application to induction motors, IEEE Conference on Decision and Control and European Control Conference, 2011. ,
DOI : 10.1109/CDC.2011.6161224
URL : https://hal.archives-ouvertes.fr/hal-00639678
Sensorless Control of Induction Machines—With or Without Signal Injection?, IEEE Transactions on Industrial Electronics, vol.53, issue.1, pp.7-30, 2006. ,
DOI : 10.1109/TIE.2005.862324
A sliding mode observer for sensorless induction motor speed regulation, International Journal of Systems Science, vol.38, issue.11, pp.913-929, 2007. ,
DOI : 10.1109/41.887957
On Sensorless Induction Motor Drives: Sliding-Mode Observer and Output Feedback Controller, IEEE Transactions on Industrial Electronics, vol.56, issue.9, pp.3404-3413, 2009. ,
DOI : 10.1109/TIE.2009.2026387
URL : https://hal.archives-ouvertes.fr/inria-00531078
A robust sensorless output feedback controller of the induction motor drives: new design and experimental validation, International Journal of Control, vol.35, issue.1, pp.484-497, 2010. ,
DOI : 10.1007/978-3-642-84379-2
URL : https://hal.archives-ouvertes.fr/inria-00450963
Sliding mode observers for fault detection and isolation, Automatica, vol.36, issue.4, pp.541-553, 2000. ,
DOI : 10.1016/S0005-1098(99)00177-6
On the robust fault detection via a sliding mode disturbance observer, International Journal of Control, vol.4, issue.7, pp.622-629, 2004. ,
DOI : 10.1016/0005-1098(76)90041-8
URL : https://hal.archives-ouvertes.fr/hal-00762283
Robust exact differentiation via sliding mode technique, Automatica, vol.34, issue.3, pp.379-384, 1998. ,
DOI : 10.1016/S0005-1098(97)00209-4
Second-order sliding-mode observer for mechanical systems, IEEE Transactions on Automatic Control, vol.50, issue.11, pp.1785-1789, 2005. ,
DOI : 10.1109/TAC.2005.858636
Describing function analysis of second-order sliding mode observers, International Journal of Systems Science, vol.38, issue.10, pp.817-824, 2007. ,
DOI : 10.1109/21.87057
Super twisting algorithm-based step-by-step sliding mode observers for nonlinear systems with unknown inputs, International Journal of Systems Science, vol.32, issue.10, 2007. ,
DOI : 10.1109/9.975511
URL : https://hal.archives-ouvertes.fr/inria-00128137
Higher Order Sliding Mode Observers, International Journal of Systems Science, vol.38, pp.771-772, 2007. ,
Sensorless second order sliding mode observer for induction motor, 2010 IEEE International Conference on Control Applications, 1933. ,
DOI : 10.1109/CCA.2010.5611102
URL : https://hal.archives-ouvertes.fr/inria-00531067
Implicit fault tolerant control: application to induction motors, Automatica, pp.355-371, 2004. ,
A Fault-Tolerant Control Architecture for Induction Motor Drives in Automotive Applications, IEEE Transactions on Vehicular Technology, vol.53, issue.6, pp.1847-1855, 2004. ,
DOI : 10.1109/TVT.2004.833610
URL : https://hal.archives-ouvertes.fr/hal-00531231
Effective fault tolerant control design for nonlinear systems: application to a class of motor control system, IET Control Theory and Application, pp.762-772, 2008. ,
DOI : 10.1049/iet-cta:20070090
Fault tolerant control for induction motors using sliding mode observers, 2010 11th International Workshop on Variable Structure Systems (VSS), pp.190-196, 2010. ,
DOI : 10.1109/VSS.2010.5544682
URL : https://hal.archives-ouvertes.fr/hal-00772797
Commande des moteurs asynchrones 2, Optimisation, discrétisation et observateurs, Edition Hermes Science, 2000. ,
Practical Stability of Nonlinear Time-Varying Cascade Systems, Journal of Dynamical and Control Systems, vol.34, issue.3, pp.45-62, 2009. ,
DOI : 10.1007/s10883-008-9057-5
Backstepping control design and its applications to vehicle lateral control in automated highway systems, 1996. ,
Adaptive robust control of nonlinear systems with application to control of mechanical systems, 39] A. Glumineau, R. Boisliveau (IRCCyN) and L. Loron (IREENA), 1996. ,
