Sequential Transfer in Multi-armed Bandit with Finite Set of Models
Learning from prior tasks and transferring that experience to improve future performance is critical for building lifelong learning agents. Although results in supervised and reinforcement learning show that transfer may significantly improve the learning performance, most of the literature on transfer is focused on batch learning tasks. In this paper we study the problem of \textit{sequential transfer in online learning}, notably in the multi--armed bandit framework, where the objective is to minimize the total regret over a sequence of tasks by transferring knowledge from prior tasks. Under the assumption that the tasks are drawn from a stationary distribution over a finite set of models, we define a novel bandit algorithm based on a method-of-moments approach for the estimation of the possible tasks and derive regret bounds for it. We introduce a novel bandit algorithm based on a method-of-moments approach for estimating the possible tasks and derive regret bounds for it. Finally, we report preliminary empirical results confirming the theoretical findings.
