Abstract : Penalised likelihood criteria such as AIC or BIC are popular methods used to deal with model selection and require to compute the maximised likelihood. Unfortunately, this maximised likelihood can be untractable, as it is the case for the latent block model (LBM). LBM is a mixture model that allows to perform the simultaneous clustering of rows and columns of large data matrices, also known as coclustering. Due to the complex dependency structure of the bservations conditionally to the row and column labels, approximations must be defined to perform the E step of the EM algorithm, leading to a lower bound of the maximised likelihood. For the same reason, the usual asymptotic approximation used to derive BIC is itself questionable. On the other hand, the integrated completed likelihood criterion (ICL) is exactly computed for LBM, but requires to investigate the influence of hyperparameters. This influence is investigated, links between the criteria are discussed and numerical experiments on both simulated and real data sets highlight the proposed model selection procedure.
