Titanium: a high-performance Java dialect, Concurrency: Practice and Experience, vol.10, issue.11-13, pp.11-13, 1998. ,
DOI : 10.1002/(SICI)1096-9128(199809/11)10:11/13<825::AID-CPE383>3.0.CO;2-H
Parallel Programmability and the Chapel Language, International Journal of High Performance Computing Applications, vol.21, issue.3, pp.291-312, 2007. ,
DOI : 10.1177/1094342007078442
Co-array Fortran for parallel programming, ACM SIGPLAN Fortran Forum, vol.17, issue.2, pp.1-31, 1998. ,
DOI : 10.1145/289918.289920
UPC language specifications, Lawrence Berkeley National Lab Tech Report LBNL?, vol.59208, 2005. ,
Habanero-Java, Proceedings of the 9th International Conference on Principles and Practice of Programming in Java, PPPJ '11, pp.51-61, 2011. ,
DOI : 10.1145/2093157.2093165
The polyhedral model, Encyclopedia of Parallel Programming, 2011. ,
Array dataflow analysis for polyhedral X10 programs, In: PPoPP, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00761537
Counting Integer Points in Parametric Polytopes Using Barvinok's Rational Functions, Algorithmica, vol.48, issue.1, 2007. ,
DOI : 10.1007/s00453-006-1231-0
Basic compiler algorithms for parallel programs, PPoPP '99, pp.1-12, 1999. ,
Counting solutions to linear and nonlinear constraints through Ehrhart polynomials: applications to analyze and transform scientific programs, ICS '96, pp.278-285, 1996. ,
DOI : 10.1145/2591635.2667172
URL : https://hal.archives-ouvertes.fr/hal-01100306
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
Scanning polyhedra with DO loops, Proc. third SIGPLAN Symp. on Principles and Practice of Parallel Programming, pp.39-50, 1991. ,
URL : https://hal.archives-ouvertes.fr/hal-00752774
Barrier inference, Proceedings of the 25th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '98, pp.342-354, 1998. ,
DOI : 10.1145/268946.268974
Concurrency Analysis for Parallel Programs with Textually Aligned Barriers, In: LCPC, 2005. ,
DOI : 10.1007/978-3-540-69330-7_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.133.2387
A linear-time algorithm for optimal barrier placement, Proceedings of the tenth ACM SIGPLAN symposium on Principles and practice of parallel programming , PPoPP '05, pp.26-35, 2005. ,
DOI : 10.1145/1065944.1065949
Compile-Time Analysis and Specialization of Clocks in Concurrent Programs, Compiler Construction. CC '09, pp.48-62, 2009. ,
DOI : 10.1007/978-3-642-00722-4_5
Compiler optimizations for eliminating barrier synchronization, PPoPP '95, pp.144-155, 1995. ,
Compiling for scalable multiprocessors with Polaris, Parallel Processing Letters, vol.07, issue.04, pp.425-436, 1997. ,
Reducing task creation and termination overhead in explicitly parallel programs, Proceedings of the 19th international conference on Parallel architectures and compilation techniques, PACT '10, pp.169-180, 2010. ,
DOI : 10.1145/1854273.1854298
