Merging two tactile stimulation principles: electrovibration and squeeze film effect
Electrovibration and squeeze film effect can modify the perception a user has of a flat surface. These two stimulation principles are compatible, which means that they can be used at the same time on the same tactile stimulator. This paper first highlights the differences between the two principles, then gives experimental results obtained when merging, with specific conditions, these two stimulation principles.
