Towards Domain Decomposition with Balanced Halo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nested Dissection has been introduced by A. George and is a well-known and very popular heuristic for sparse matrix ordering to reduce both the fill-in and the operation count during the numerical factorization. Considering now hybrid methods mixing both direct and iterative solvers, obtaining a domain decomposition leading to a good balancing of both the size of domain interiors and the size of interfaces is a key point for load balancing and efficiency in a parallel context. For this purpose, we revisit the algorithm introduced by Lipton, Rose and Tarjan which per- formed the recursion in a different manner.
abstract1_HiePACS.pdf (171.78 Ko) Télécharger le fichier
hal-00924977 , version 1 (07-01-2014)
  • HAL Id : hal-00924977 , version 1
Astrid Casadei, Luc Giraud, Pierre Ramet, Jean Roman. Towards Domain Decomposition with Balanced Halo. Workshop Celebrating 40 Years of Nested Dissection, Jul 2013, Waterloo, Canada. ⟨hal-00924977⟩
Collections
CNRS INRIA INRIA2
300 Consultations
191 Téléchargements
