Predicting the effects of illumination in shape from shading - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Vision Année : 2013
Shading depends on different interactions between surface geometry and lighting. Under collimated illumination, shading is dominated by the 'direct' term, in which image intensities vary with the angle between surface normals and light sources. Diffuse illumination, by contrast, is dominated by 'vignetting effects' in which image intensities vary with the degree of self-occlusion (the proportion of incoming direction that each surface point 'sees'). These two types of shading thus lead to very different intensity patterns, which raises the question of whether shading inferences are based directly on image intensities. We show here that the visual system uses 2D orientation signals ('orientation fields') to estimate shape, rather than raw image intensities and an estimate of the illuminant. We rendered objects under varying illumination directions designed to maximize the effects of illumination on the image. We then passed these images through monotonic, non-linear intensity transfer functions to decouple luminance information from orientation information, thereby placing the two signals in conflict. In Task 1 subjects adjusted the 3D shape of match objects to report the illusory effects of changes of illumination direction on perceived shape. In Task 2 subjects reported which of a pair of points on the surface appeared nearer in depth. They also reported perceived illumination directions for all stimuli. We find that the substantial misperceptions of shape are well predicted by orientation fields, and poorly predicted by luminance-based shape from shading. For the untransformed images illumination could be estimated accurately, but not for the transformed images. Thus shape perception was, for these examples, independent of the ability to estimate the lighting. Together these findings support neurophysiological estimates of shape from the responses of orientation selective cell populations, irrespective of the illumination conditions.
Mots clés
hal-00925016 , version 1 (07-01-2014)
Roland Fleming, Romain Vergne, Steven Zucker. Predicting the effects of illumination in shape from shading. Journal of Vision, 2013, Vision Sciences Society Meeting, 2013: Abstracts, 13 (9), pp.article 611. ⟨10.1167/13.9.611⟩. ⟨hal-00925016⟩
315 Consultations
0 Téléchargements
