Diffraction at a Curved Grating: TM and TE Cases, Homogenization, Journal of Mathematical Analysis and Applications, vol.202, issue.3, pp.995-1026, 1996. ,
DOI : 10.1006/jmaa.1996.0357
Reconstruction of small interface changes of an inclusion from modal measurements II: The elastic case, Journal de Math??matiques Pures et Appliqu??es, vol.94, issue.3, pp.322-339, 2010. ,
DOI : 10.1016/j.matpur.2010.02.001
Time-Harmonic Electromagnetic Fields in Thin Chiral Curved Layers, SIAM Journal on Mathematical Analysis, vol.29, issue.2, pp.395-423, 1998. ,
DOI : 10.1137/S0036141096305504
High-frequency asymptotic analysis of a dissipative transmission problem resulting in generalized impedance boundary conditions, Asymptot. Anal, vol.26, pp.3-4257, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00347873
The Effect of a Thin Coating on the Scattering of a Time-Harmonic Wave for the Helmholtz Equation, SIAM Journal on Applied Mathematics, vol.56, issue.6, pp.1664-1693, 1996. ,
DOI : 10.1137/S0036139995281822
Asymptotic expansion of the solution of an interface problem in a polygonal domain with thin layer, Asymptot. Anal, vol.50, issue.12, pp.121-173, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00001555
On the influence of the geometry on skin effect in electromagnetism, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.9-12, pp.9-121053, 2011. ,
DOI : 10.1016/j.cma.2010.11.011
URL : https://hal.archives-ouvertes.fr/hal-00503170
Corner Singularities and Analytic Regularity for Linear Elliptic Systems. Part I: Smooth domains ,
URL : https://hal.archives-ouvertes.fr/hal-00453934
Equivalent Conditions for Elasto-Acoustics, Waves 2013: The 11th International Conference on Mathematical and Numerical Aspects of Waves, pp.345-346, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00842571
Un probl??me Spectral Issu d'un Couplage Elasto-Acoustique, ESAIM: Mathematical Modelling and Numerical Analysis, vol.34, issue.4, pp.835-857, 2000. ,
DOI : 10.1051/m2an:2000106
Effective boundary condition for acoustic and electromagnetic scattering in thin layers, 1993. ,
GENERALIZED IMPEDANCE BOUNDARY CONDITIONS FOR SCATTERING PROBLEMS FROM STRONGLY ABSORBING OBSTACLES: THE CASE OF MAXWELL'S EQUATIONS, Mathematical Models and Methods in Applied Sciences, vol.18, issue.10, pp.1787-1827, 2008. ,
DOI : 10.1142/S0218202508003194
An ultra-weak method for acoustic fluid???solid interaction, Journal of Computational and Applied Mathematics, vol.213, issue.1, pp.166-185, 2008. ,
DOI : 10.1016/j.cam.2006.12.030
LOW-FREQUENCY SCATTERING BY A BODY IN LUBRICATED CONTACT, The Quarterly Journal of Mechanics and Applied Mathematics, vol.36, issue.1, pp.111-138, 1983. ,
DOI : 10.1093/qjmam/36.1.111
Diffraction in the high frequency regime by a thin layer of dielectric material I: The equivalent impedance boundary condition, SIAM Journal on Applied Mathematics, vol.59, issue.3, pp.1028-1052, 1999. ,
DOI : 10.1137/S0036139996307152
Leprobì eme de Ventcel pour le système de l'´ elasticité dans un domaine de R 3, C. R. Acad. Sci. Paris Sér. I Math, vol.304, issue.6, pp.151-154, 1987. ,
Approximate boundary conditions for the electromagnetic field on the surface of a good conductor, Investigations on radiowave propagation, pp.5-12, 1948. ,
Fluid???Solid Interaction: Acoustic Scattering by a Smooth Elastic Obstacle, SIAM Journal on Applied Mathematics, vol.55, issue.4, pp.904-922, 1995. ,
DOI : 10.1137/S0036139993259027
An inverse fluid-solid interaction problem, Inverse Probl. Imaging, vol.3, issue.2, pp.173-198, 2009. ,
Fluid-structure interaction problems, Mathematical aspects of boundary element methods, pp.252-262, 1998. ,
Equivalent Boundary Conditions for an Elasto-Acoustic Problem set in a Domain with a Thin Layer, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, issue.5, 2013. ,
DOI : 10.1051/m2an/2014002
Calcul du skin effect par la méthode des perturbations, Journal of Physics, vol.11, issue.3, pp.233-242, 1940. ,
