Estimation of the viscoelastic properties of vessel walls using a computational model and Doppler ultrasound, Physics in Medicine and Biology, vol.55, issue.12, p.553557, 2010. ,
DOI : 10.1088/0031-9155/55/12/019
Noninvasive Young's modulus evaluation of tissues surrounding pulsatile vessels using ultrasound doppler measurement, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, vol.54, issue.6, pp.1265-1271, 2007. ,
DOI : 10.1109/TUFFC.2007.379
Estimation techniques for distributed parameter systems, volume 1 of Systems & Control: Foundations & Applications, Birkhäuser Boston Inc, 1989. ,
Automatic segmentation of medical images using image registration: diagnostic and simulation applications, Journal of Medical Engineering & Technology, vol.19, issue.2, pp.53-63, 2005. ,
DOI : 10.1080/03091900412331289889
Efficient computational fluid dynamics mesh generation by image registration, Medical Image Analysis, vol.11, issue.6, pp.648-662, 2007. ,
DOI : 10.1016/j.media.2007.06.011
Registration based segment growing for vascular segmentation, 2012. ,
Forward and inverse problems in fluid-stucture interaction. Application to hemodynamics, 2012. ,
Fractional-Step Schemes for the Coupling of Distributed and Lumped Models in Hemodynamics, SIAM Journal on Scientific Computing, vol.35, issue.3, pp.551-575, 2013. ,
DOI : 10.1137/120874412
URL : https://hal.archives-ouvertes.fr/hal-00690493
State observers of a vascular fluid???structure interaction model through measurements in the solid, Computer Methods in Applied Mechanics and Engineering, vol.256, pp.149-168, 2013. ,
DOI : 10.1016/j.cma.2012.12.010
URL : https://hal.archives-ouvertes.fr/hal-00764332
Sequential parameter estimation for fluid-structure problems: Application to hemodynamics, International Journal for Numerical Methods in Biomedical Engineering, vol.36, issue.1-2, pp.434-455, 2012. ,
DOI : 10.1002/cnm.1476
URL : https://hal.archives-ouvertes.fr/inria-00603399
Vascular ultrasound for atherosclerosis imaging, Interface Focus, vol.104, issue.1, pp.565-575, 2011. ,
DOI : 10.1161/hc2601.091704
Applications of variational data assimilation in computational hemodynamics, 2011. ,
Algorithms for fluid-structure interaction problems, Cardiovascular Mathematics. Modeling and simulation of the circulatory system, chapter 9, pp.307-346, 2009. ,
DOI : 10.1007/978-88-470-1152-6_9
A projection algorithm for fluid???structure interaction problems with strong added-mass effect, Comptes Rendus Mathematique, vol.342, issue.4, pp.279-284, 2006. ,
DOI : 10.1016/j.crma.2005.12.017
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
Gmsh: A 3-D finite element mesh generator with built-in pre- and post-processing facilities, International Journal for Numerical Methods in Engineering, vol.69, issue.4, pp.791309-1331, 2009. ,
DOI : 10.1002/nme.2579
A simplified reduced order Kalman filtering and application to altimetric data assimilation in Tropical Pacific, Journal of Marine Systems, vol.36, issue.1-2, pp.101-127, 2002. ,
DOI : 10.1016/S0924-7963(02)00129-X
A new approach for filtering nonlinear systems, Proceedings of 1995 American Control Conference, ACC'95, pp.1628-1632, 1995. ,
DOI : 10.1109/ACC.1995.529783
A new method for the nonlinear transformation of means and covariances in filters and estimators. Automatic Control, IEEE Transactions on, vol.45, issue.3, pp.477-482, 2000. ,
An inverse technique to deduce the elasticity of a large artery, The European Physical Journal Applied Physics, vol.9, issue.2, pp.153-163, 1999. ,
DOI : 10.1051/epjap:2000213
Expert consensus document on arterial stiffness: methodological issues and clinical applications, European Heart Journal, vol.27, issue.21, pp.272588-2605, 2006. ,
DOI : 10.1093/eurheartj/ehl254
Parameter identification for a one-dimensional blood flow model, ESAIM-Proceedings, pp.174-200, 2005. ,
DOI : 10.1051/proc:2005014
URL : https://hal.archives-ouvertes.fr/hal-00700366
Sequential identification of boundary support parameters in a fluid-structure vascular model using patient image data, Biomechanics and Modeling in Mechanobiology, pp.1-22, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00760703
Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems, ESAIM: Control, Optimisation and Calculus of Variations, vol.17, issue.2, pp.380-405, 2011. ,
DOI : 10.1051/cocv/2010006
URL : https://hal.archives-ouvertes.fr/inria-00550104
Filtering for distributed mechanical systems using position measurements: perspectives in medical imaging, Inverse Problems, vol.25, issue.3, pp.35010-035035, 2009. ,
DOI : 10.1088/0266-5611/25/3/035010
URL : https://hal.archives-ouvertes.fr/hal-00358914
External tissue support and fluid???structure simulation in blood flows, Biomechanics and Modeling in Mechanobiology, vol.31, issue.3, 2011. ,
DOI : 10.1007/s10237-011-0289-z
URL : https://hal.archives-ouvertes.fr/hal-00701801
McDonald's blood flow in arteries: theoretical, experimental and clinical principles, 2005. ,
Reduced models of the cardiovascular system, Cardiovascular Mathematics. Modeling and simulation of the circulatory system, chapter 10, pp.347-394, 2009. ,
DOI : 10.1007/978-88-470-1152-6_10
A Variational Approach for Estimating the Compliance of the Cardiovascular Tissue: An Inverse Fluid-Structure Interaction Problem, SIAM Journal on Scientific Computing, vol.33, issue.3 ,
DOI : 10.1137/100808277
Filtres de Kalman singuliersévolutifssinguliersévolutifs pour l'assimilation de données en océanographie, Comptes Rendus de l'Académie des Sciences -Series IIA, pp.255-260, 1998. ,
Determination of human arterial wall parameters from clinical data, Biomechanics and Modeling in Mechanobiology, vol.2, issue.2, pp.141-148, 2009. ,
DOI : 10.1007/s10237-008-0124-3
Vascular wall elasticity measurement by magnetic resonance imaging, Magnetic Resonance in Medicine, vol.35, issue.3, pp.593-600, 2006. ,
DOI : 10.1002/mrm.20991
Assessment of stiffness changes in the ex vivo porcine aortic wall using magnetic resonance elastography, Magnetic Resonance Imaging, vol.30, issue.1, pp.122-127, 2012. ,
DOI : 10.1016/j.mri.2011.09.009
