Numerical Reconstruction of Convex Polytopes from Directional Moments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We reconstruct an n-dimensional convex polytope from the knowledge of its directional moments up to a certain order. The directional moments are related to the projection of the polytope's vertices on a particular direction. To extract the vertex coordinates from the moment information we combine established numerical algorithms such as generalized eigenvalue computation and linear interval interpolation. Numerical illustrations are given for the reconstruction of 2-d and 3-d objects.
CollowaldNumericalPolytopes.pdf (708.83 Ko) Télécharger le fichier
hal-00926357 , version 1 (13-01-2014)
hal-00926357 , version 2 (23-01-2014)
  • HAL Id : hal-00926357 , version 1
Mathieu Collowald, Annie Cuyt, Evelyne Hubert, Wen-Shin Lee, Oliver Salazar Celis. Numerical Reconstruction of Convex Polytopes from Directional Moments. 2013. ⟨hal-00926357v1⟩
397 Consultations
489 Téléchargements
