Large-scale data visualization using parallel data streaming, IEEE Computer Graphics and Applications, vol.21, issue.4, pp.34-41, 2001. ,
DOI : 10.1109/38.933522
A Parallel Approach for Efficiently Visualizing Extremely Large, Time-Varying Datasets, 2000. ,
Libkomp, an efficient openmp runtime system for both fork-join and data flow paradigms, Proceedings of the 8th international conference on OpenMP in a Heterogeneous World IWOMP'12, pp.102-115 ,
Cilk: An Efficient Multithreaded Runtime System, Journal of Parallel and Distributed Computing, vol.37, issue.1, pp.55-69, 1996. ,
DOI : 10.1006/jpdc.1996.0107
A Proposal to Extend the OpenMP Tasking Model with Dependent Tasks, International Journal of Parallel Programming, vol.26, issue.6, pp.292-305, 2009. ,
DOI : 10.1007/s10766-009-0101-1
The implementation of the cilk-5 multithreaded language. SIGPLAN Not, pp.212-223, 1998. ,
KAAPI: A thread scheduling runtime system for data flow computations on cluster of multi-processors, Proceedings of PASCO'07, p.3, 2007. ,
Flat combining and the synchronization-parallelism tradeoff, Proceedings of the 22nd ACM symposium on Parallelism in algorithms and architectures SPAA '10, ACM, pp.355-364, 2010. ,
The problem with threads, Computer, vol.39, pp.33-42, 2006. ,
X- Kaapi C programming interface, p.3, 2011. ,
The X- Kaapi's Application Programming Interface. Part I: Data Flow Programming, 2011. ,
Dax toolkit: A proposed framework for data analysis and visualization at extreme scale, Large Data Analysis and Visualization (LDAV), pp.97-104, 2011. ,
Work-preserving speed-up of parallel matrix computations, SIAM J. Comput, issue.4, 1995. ,
Optimization via reflection on work stealing in TBB, IPDPS, 2008. ,
Piston: A portable cross-platform framework for data-parallel visualization operators, Eurographics Symposium on Parallel Graphics ans Visualization, 2012. ,
Cache-efficient parallel isosurface extraction for shared cache multicores, Eurographics Symposium on Parallel Graphics ans Visualization, 2010. ,
Hyperflow: A heterogeneous dataflow architecture, Eurographics Symposium on Parallel Graphics ans Visualization, p.8, 2012. ,
Streaming-Enabled Parallel Dataflow Architecture for Multicore Systems, Eurographics/IEEE-VGTC Symposium on Visualization, pp.1073-1082, 2010. ,
DOI : 10.1111/j.1467-8659.2009.01704.x
