Non-linear regression models, Handbook of Econometrics, pp.333-389, 1983. ,
The variational Kalman filter and an efficient implementation using limited memory BFGS, International Journal for Numerical Methods in Fluids, vol.63, issue.1-3, pp.314-350, 2010. ,
DOI : 10.1002/fld.2153
Introduction to Matrix Analysis, 1960. ,
A strategy for operational implementation of 4D-Var, using an incremental approach, Quarterly Journal of the Royal Meteorological Society, vol.45, issue.519, pp.1367-1388, 1994. ,
DOI : 10.1002/qj.49712051912
A Sequential Variational Algorithm for Data Assimilation in Oceanography and Meteorology, Monthly Weather Review, vol.137, issue.1, pp.269-287, 2009. ,
DOI : 10.1175/2008MWR2500.1
Applied Regression Analysis, 1966. ,
DOI : 10.1002/9781118625590
Sequential data assimilation with a nonlinear quasigeostrophic model using Monte-Carlo methods to forecast error statistics, J. Geophys. Res, pp.9910143-10162, 1994. ,
The Ensemble Kalman Filter: theoretical formulation and practical implementation, Ocean Dynamics, vol.53, issue.4, pp.343-367, 2003. ,
DOI : 10.1007/s10236-003-0036-9
Estimating the covariance matrices of analysis and forecast error in variational data assimilation, 1995. ,
Nonlinear Differential Equations. - Amsterdam, 1980. ,
On Analysis Error Covariances in Variational Data Assimilation, SIAM Journal on Scientific Computing, vol.30, issue.4, pp.1847-1874, 2008. ,
DOI : 10.1137/07068744X
URL : https://hal.archives-ouvertes.fr/inria-00391893
On optimal solution error covariances in variational data assimilation problems, Journal of Computational Physics, vol.229, issue.6, pp.2292159-2178, 2010. ,
DOI : 10.1016/j.jcp.2009.11.028
URL : https://hal.archives-ouvertes.fr/hal-00787292
Computation of the optimal solution error covariance in variational data assimilation problems with nonlinear dynamics, Journal of Computational Physics, pp.23079-7943, 2011. ,
TAPENADE 2.1 user's guide, 2004. ,
Nonlinear Least Squares Estimation, The Annals of Mathematical Statistics, vol.36, issue.2, pp.638-650, 1965. ,
DOI : 10.1214/aoms/1177700171
On Asymptotic Posterior Normality for Stochastic Processes, J. Roy. Stat. Soc. B41, pp.184-189, 1979. ,
DOI : 10.1007/978-1-4419-5823-5_45
Asymptotic properties of nonlinear least square estimation, Annals of Mathematical Statistics, issue.40, pp.633-643, 1969. ,
Bayesian Asymptotic Theory in a Time Series Model with a Possible Nonstationary Process, Econometric Theory, vol.47, issue.3-4, pp.764-773, 1994. ,
DOI : 10.2307/2938280
Approximate iterative methods for variational data assimilation, International Journal for Numerical Methods in Fluids, vol.108, issue.10-11, pp.1-6, 2005. ,
DOI : 10.1002/fld.851
Second-Order Information in Data Assimilation*, Monthly Weather Review, vol.130, issue.3, pp.629-648, 2002. ,
DOI : 10.1175/1520-0493(2002)130<0629:SOIIDA>2.0.CO;2
URL : https://hal.archives-ouvertes.fr/hal-00787272
On deterministic error analysis in variational data assimilation. Nonlinear Processes in Geophysics, pp.481-490, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00331085
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, pp.97-110, 1986. ,
DOI : 10.1111/j.1600-0870.1986.tb00459.x
ARPACK Users Guide: Solution of Large-Scale Eigenvalue Problems with Implicitly Copyright c, Royal Meteorological Society Q. J. R. Meteorol. Soc, vol.00, pp.2-24, 1988. ,
DOI : 10.1137/1.9780898719628
Contrôle optimal des systèmes gouvernés par des ´ equations aux dérivées partielles, 1968. ,
On the limited memory BFGS method for large scale minimization, pp.503-528, 1989. ,
Analysis methods for numerical weather prediction, Quarterly Journal of the Royal Meteorological Society, vol.108, issue.474, pp.1177-1194, 1986. ,
DOI : 10.1002/qj.49711247414
Adjoint Equations and Perturbation Algorithms in Nonlinear Problems, 1996. ,
A Differential Geometric Approach to the Geometric Mean of Symmetric Positive-Definite Matrices, SIAM Journal on Matrix Analysis and Applications, vol.26, issue.3, 2005. ,
DOI : 10.1137/S0895479803436937
Large sample estimation and hypothesis testing, pp.2111-2245, 1994. ,
Numerical Heat Transfer and Fluid Flow, 1980. ,
A variational initialization method for the fields of the meteorological elements, Soviet Meteorology and Hydrology (English translation), pp.1-11, 1976. ,
Estimating the 4DVAR analysis error of GODAE products. Ocean Dynamics, pp.121-138, 2009. ,
Four-Dimensional Assimilation In the Presence of Baroclinic Instability, Quarterly Journal of the Royal Meteorological Society, vol.119, issue.506, pp.649-672, 1992. ,
DOI : 10.1002/qj.49711850604
Nonlinear Regression Modelling: a Unified Practical Approach, 1983. ,
A fundamental study of the numerical prediction based on the variational principles, J. Meteor. Soc. Japan, issue.33, pp.262-275, 1955. ,
Inverse problems: A Bayesian perspective, Acta Numerica, vol.19, pp.451-559, 2010. ,
DOI : 10.1017/S0962492910000061
Inverse Problems Theory: Methods for Data Fitting and Model Parameter Estimation, 1987. ,
Inverse Problems Theory and Methods for Model Parameter Estimation, 2005. ,
DOI : 10.1137/1.9780898717921
The role of the Hessian matrix in fitting models to measurements, Journal of Geophysical Research, vol.93, issue.C5, pp.6177-6196, 1989. ,
DOI : 10.1029/JC094iC05p06177
Four-dimensional variational data assimilation using the adjoint of a multilevel primitive-equation model, Quarterly Journal of the Royal Meteorological Society, vol.110, issue.502, pp.1225-1254, 1991. ,
DOI : 10.1002/qj.49711750206
Solution of incorrectly formulated problems and the regularization method. English translation of, Dokl. Akad. Nauk SSSR, issue.151, pp.501-504, 1963. ,
Limitedmemory preconditioners, with application to incremental fourdimensional variational assimilation. Q, J. R. Meteorol. Soc, issue.134, pp.751-769, 2008. ,
A Bayesian tutorial for data assimilation, Physica D: Nonlinear Phenomena, vol.230, issue.1-2, pp.1-16, 2007. ,
DOI : 10.1016/j.physd.2006.09.017
Nonlinear Regression with Dependent Observations, Econometrica, vol.52, issue.1, pp.143-162, 1984. ,
DOI : 10.2307/1911465
A New Hessian Preconditioning Method Applied to Variational Data Assimilation Experiments Using NASA General Circulation Models, Monthly Weather Review, vol.124, issue.5, pp.1000-1017, 1996. ,
DOI : 10.1175/1520-0493(1996)124<1000:ANHPMA>2.0.CO;2
Asymptotics of Estimating Equations under Natural Conditions, Journal of Multivariate Analysis, vol.65, issue.2, pp.65245-260, 1998. ,
DOI : 10.1006/jmva.1997.1731
The Maximum Likelihood Ensemble Filter as a non???differentiable minimization algorithm, Quarterly Journal of the Royal Meteorological Society, vol.133, issue.C5, 2008. ,
DOI : 10.1002/qj.251
