Implementing a formal model of inflectional morphology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Inflectional morphology as a research topic lies on the crossroads of many linguistic subfields, such as linguistic description, linguistic typology, formal linguistics and computational linguistics. However, the subject itself is tackled with diverse objectives and approaches each time. In this paper, we describe the implementation of a formal model of inflectional morphology capturing typological generalisations that aims at combining efforts made in each subfield giving access to every one of them to valuable methods and/or data that would have been out of range otherwise. We show that both language description and studies in formal morphology and linguistic typology on the one hand, as well as NLP tool and resource development on the other benefit from the availability of such a model and an implementation thereof.
sfcm13.pdf (560.36 Ko) Télécharger le fichier
hal-00927277 , version 1 (12-01-2014)
Benoît Sagot, Géraldine Walther. Implementing a formal model of inflectional morphology. Third International Workshop on Systems and Frameworks for Computational Morphology, Humboldt-Universität, Sep 2013, Berlin, Germany. pp.115-134, ⟨10.1007/978-3-642-40486-3_7⟩. ⟨hal-00927277⟩
258 Consultations
482 Téléchargements
