Approximating Functions on a Mesh with Restricted Voronoi Diagrams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2013
Bruno Lévy
We propose a method that computes a piecewise constant approximation of a function defined on a mesh. The approximation is associated with the cells of a restricted Voronoi diagram. Our method optimizes an objective function measuring the quality of the approximation. This objective function depends on the placement of the samples that define the restricted Voronoi diagram and their associated function values. We study the continuity of the objective function, derive the closed-form expression of its derivatives and use them to design a numerical solution mechanism. The method can be applied to a function that has discontinuities, and the result aligns the boundaries of the Voronoi cells with the discontinuities. Some examples are shown, suggesting potential applications in image vectorization and compact representation of lighting.
vorapprox.pdf (4.94 Mo) Télécharger le fichier
hal-00929994 , version 1 (20-10-2017)
Vincent Nivoliers, Bruno Lévy. Approximating Functions on a Mesh with Restricted Voronoi Diagrams. Computer Graphics Forum, 2013, 32 (5), pp.83-92. ⟨10.1111/cgf.12175⟩. ⟨hal-00929994⟩
308 Consultations
274 Téléchargements
