New interface
Journal articles
A front tracking method for a strongly coupled PDE-ODE system with moving density constraints in traffic flow
Maria Laura Delle Monache 1 Paola Goatin 1
1 OPALE - Optimization and control, numerical algorithms and integration of complex multidiscipline systems governed by PDE
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
Abstract : In this paper we introduce a numerical method for tracking a bus trajectory on a road network. The mathematical model taken into consideration is a strongly coupled PDE-ODE system: the PDE is a scalar hyperbolic conservation law describing the traffic flow while the ODE, that describes the bus trajectory, needs to be intended in a Carathéodory sense. The moving constraint is given by an inequality on the flux which accounts for the bottleneck created by the bus on the road. The finite volume algorithm uses a locally non-uniform moving mesh which tracks the bus position. Some numerical tests are shown to describe the behavior of the solution.
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-00930031
Contributor : Maria Laura Delle Monache Connect in order to contact the contributor
Submitted on : Friday, January 24, 2014 - 11:15:12 AM
Last modification on : Friday, August 5, 2022 - 3:51:05 AM
Long-term archiving on: : Thursday, April 24, 2014 - 10:06:39 PM
File
TRAM2DelleMonacheGoatin.pdf
Identifiers
  • HAL Id : hal-00930031, version 1
Citation
Maria Laura Delle Monache, Paola Goatin. A front tracking method for a strongly coupled PDE-ODE system with moving density constraints in traffic flow. Discrete and Continuous Dynamical Systems - Series S, 2014, 7 (3), pp.435-447. ⟨hal-00930031⟩
Share
Metrics
Record views
659
Files downloads
515
