PCMs inside emulsions : some specific aspects related to DSC-like configurations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Energy Année : 2013
The heat transfer characteristics during melting of the (phase change material) PCM dispersed inside an emulsion are investigated theoretically and experimentally by using (differential scanning calorimeter) DSC. Genetic algorithm is used to determine the unknown parameters in the physical model. The dispersed PCMs are hexadecane, heptadecane and octadecane. Energy analysis is carried out to understand the thermal behavior of the simple and mixed emulsions. The effect of the heating rate on the thermal behavior of emulsion is also analyzed.
hal-00930077 , version 1 (14-01-2014)
Tarik Kousksou, Tarik El Rhafiki, Mustapha Madhaoui, Pascal Bruel, Youssef Zeraouli. PCMs inside emulsions : some specific aspects related to DSC-like configurations. Energy, 2013, 56, pp.175-183. ⟨10.1016/j.energy.2013.04.040⟩. ⟨hal-00930077⟩
78 Consultations
0 Téléchargements
