Zubov's equation for state-constrained perturbed nonlinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Control and Related Fields Année : 2015
The paper gives a characterization of the uniform robust domain of attraction for a nite non-linear controlled system subject to perturbations and state constraints. We extend the Zubov approach to characterize this domain by means of the value function of a suitable in nite horizon state-constrained control problem which at the same time is a Lyapunov function for the system. We provide associated Hamilton-Jacobi-Bellman equations and prove existence and uniqueness of the solutions of these generalized Zubov equations.
Zubov_obstacle_submitted.PDF (1000.14 Ko) Télécharger le fichier
hal-00931028 , version 1 (14-01-2014)
Lars Grüne, Hasnaa Zidani. Zubov's equation for state-constrained perturbed nonlinear systems. Mathematical Control and Related Fields, 2015, 5 (1), pp.55-71. ⟨10.3934/mcrf.2015.5.55⟩. ⟨hal-00931028⟩
348 Consultations
325 Téléchargements
