Address Allocation Scheme to Improve Lifetime of IPv6 Cluster-based WSNs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Leila Ben Saad
  • Fonction : Auteur correspondant
  • PersonId : 880999
Connectez-vous pour contacter l'auteur
Bernard Tourancheau
Extending the lifetime of wireless sensor networks under energy resource limitations of the sensors is a challenging problem. To reach this goal, we propose, in this paper, an address allocation scheme that maximizes the correlation in addresses. This correlation is then exploited by the sensors to reduce the size of their packets transmitted to the sink by applying source coding on addresses. The proposed approach was formulated as an optimization problem that maximizes the network lifetime. The simulation results show that a significant network lifetime improvement can be achieved by using this solution.
Fichier non déposé
hal-00931048 , version 1 (06-02-2014)
Leila Ben Saad, Bernard Tourancheau. Address Allocation Scheme to Improve Lifetime of IPv6 Cluster-based WSNs. NTMS 2012 - 5th International Conference on New Technologies, Mobility and Security, May 2012, Istanbul, Turkey. pp.131-135, ⟨10.1109/NTMS.2012.6208699⟩. ⟨hal-00931048⟩
128 Consultations
0 Téléchargements
