MODIS: an audio motif discovery software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2013
MODIS is a free speech and audio motif discovery software developed at IRISA Rennes. Motif discovery is the task of discovering and collecting occurrences of repeating patterns in the absence of prior knowledge, or training material. MODIS is based on a generic approach to mine repeating audio sequences, with tolerance to motif variability. The algorithm implementation allows to process large audio streams at a reasonable speed where motif discovery often requires huge amount of time.
Son [cs.SD]
MODIS_an_audio_motif_discovery_software.pdf (284.38 Ko) Télécharger le fichier
hal-00931227 , version 1 (15-01-2014)
  • HAL Id : hal-00931227 , version 1
Laurence Catanese, Nathan Souviraà-Labastie, Bingqing Qu, Sébastien Campion, Guillaume Gravier, et al.. MODIS: an audio motif discovery software. Show & Tell - Interspeech 2013, Aug 2013, Lyon, France. 2013. ⟨hal-00931227⟩
551 Consultations
490 Téléchargements
