An FPGA Configuration Stream Architecture Supporting Seamless Hardware Accelerator Migration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Most of the available commercial Field Programmable Gate Arrays (FPGA) use an addressable memory organized around an array of N-bit words of Static RAM (SRAM) cells. Such configuration memory is traditionally programmed by writing, to each word, the corresponding bit-stream data at runtime. In the growing domain of Dynamic Partial Reconfiguration, this leads to long reconfiguration time of dynamic regions. We propose a novel approach to task relocation in an FPGA-based reconfigurable fabric, allowing for offline design, routing and unfinalized placement of hardware IPs and dynamic placement of the corresponding bit-streams at runtime.
Fichier non déposé
hal-00931572 , version 1 (15-01-2014)
  • HAL Id : hal-00931572 , version 1
Christophe Huriaux, Olivier Sentieys, Antoine Courtay. An FPGA Configuration Stream Architecture Supporting Seamless Hardware Accelerator Migration. ConfigComp'2013, Workshop on Reconfigurable Computing V2.0: The Next Generation of Technology, Architectures and Design Tools, held in conjunction to the DATE 2013 conference, Mar 2013, Grenoble, France. ⟨hal-00931572⟩
233 Consultations
0 Téléchargements
