Surface Reconstruction by Voronoi Filtering, Discrete & Computational Geometry, vol.22, issue.4, pp.481-504, 1999. ,
DOI : 10.1007/PL00009475
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.71
A SIMPLE ALGORITHM FOR HOMEOMORPHIC SURFACE RECONSTRUCTION, International Journal of Computational Geometry & Applications, vol.12, issue.01n02, pp.125-141, 2002. ,
DOI : 10.1142/S0218195902000773
An optimal algorithm for constructing the weighted voronoi diagram in the plane, Pattern Recognition, vol.17, issue.2, pp.251-257, 1984. ,
DOI : 10.1016/0031-3203(84)90064-5
The stability of Delaunay triangulations, 2012. Submitted to International Journal of Computational Geometry and Applications (special issue for SoCG Boissonnat and J. Flötotto. A coordinate system associated with points scattered on a surface, Computer-Aided Design, vol.7, issue.1 3, pp.30161-174, 2004. ,
Manifold Reconstruction in Arbitrary Dimensions Using Witness Complexes, Discrete & Computational Geometry, vol.33, issue.2, pp.37-70, 2009. ,
DOI : 10.1007/s00454-009-9175-1
URL : https://hal.archives-ouvertes.fr/hal-00488434
Laplacian eigenmaps and spectral techniques for embedding and clustering, Advances in Neural Information Processing Systems, pp.585-591, 2002. ,
Bregman Voronoi Diagrams, Discrete & Computational Geometry, vol.12, issue.2, pp.281-307, 2010. ,
DOI : 10.1007/s00454-010-9256-1
URL : https://hal.archives-ouvertes.fr/hal-00488441
Topology and Geometry, Graduate Text in Mathematics, vol.37, p.38, 1994. ,
Discrete laplace operator on meshed surfaces, Proceedings of the twenty-fourth annual symposium on Computational geometry , SCG '08, pp.278-287, 2008. ,
DOI : 10.1145/1377676.1377725
Locally uniform anisotropic meshing, Proceedings of the twenty-fourth annual symposium on Computational geometry , SCG '08, pp.270-277, 2008. ,
DOI : 10.1145/1377676.1377724
URL : https://hal.archives-ouvertes.fr/inria-00275430
Algorithmic geometry, p.28, 1998. ,
DOI : 10.1017/CBO9781139172998
Sliver Exudation, Journal of ACM, vol.47, issue.16, pp.883-904, 2000. ,
Manifold Reconstruction from Point Samples Delaunay triangulation based surface reconstruction, Proc. ACM-SIAM Symp. Discrete Algorithms Effective Computational Geometry for Curve and Surfaces, pp.1018-1027, 2005. ,
An optimal convex hull algorithm in any fixed dimension, Discrete & Computational Geometry, vol.16, issue.4, pp.377-409, 1993. ,
DOI : 10.1007/BF02573985
On the Local Behavior of Spaces of Natural Images, Lieutier. Smooth Manifold Reconstruction from Noisy and Nonuniform Approximation with Guarantees. Comp. Geom: Theory and Applications, pp.1-12, 2008. ,
DOI : 10.1007/s11263-007-0056-x
Towards persistence-based reconstruction in euclidean spaces, Proceedings of the twenty-fourth annual symposium on Computational geometry , SCG '08, pp.232-241, 2008. ,
DOI : 10.1145/1377676.1377719
URL : https://hal.archives-ouvertes.fr/inria-00197543
Applications of random sampling in computational geometry, II, Discrete & Computational Geometry, vol.1, issue.5, pp.387-421, 1989. ,
DOI : 10.1007/BF02187740
A greedy Delaunay Based Surface Reconstruction Algorithm. The Visual Computer, pp.4-16, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00072024
PROVABLE DIMENSION DETECTION USING PRINCIPAL COMPONENT ANALYSIS, Sur la sphère vide. Izv. Akad. Nauk SSSR, Otdelenie Matematicheskii i Estestvennyka Nauk, pp.415-440, 1934. ,
DOI : 10.1142/S0218195908002702
Curve and Surface Reconstruction: Algorithms with Mathematical Analysis, 2006. ,
Hessian eigenmaps: Locally linear embedding techniques for high-dimensional data, Proceedings of the Natural Academy of Sciences, pp.5591-5596, 2003. ,
DOI : 10.1073/pnas.1031596100
Curvature Measures. Transactions of the, pp.418-491, 1959. ,
Geometric measure theory 30 [Flö03] J. Flötotto. A coordinate system associated to a point cloud issued from a manifold: definition, properties and applications, 1969. ,
Smooth-surface reconstruction in near-linear time Efficient simplicial reconstructions of manifolds from their samples, Proc. ACM-SIAM Symp. Discrete Algorithms, pp.781-780, 2002. ,
Convergence of curvature in secant approximations, Journal of Differential Geometry, vol.37, issue.9, pp.117-190, 1993. ,
Piecewise linear reconstruction and meshing of submanifolds of Euclidean space, pp.31-37, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01095861
Surface Reconstruction based on Lower Dimensional Localized Delaunay Triangulation, Proc. Eurographics, pp.363-371, 2000. ,
DOI : 10.1111/1467-8659.00439
Shape Dimension and Intrinsic Metric from Samples of Manifolds. Discrete and Computational Geometry, Li. Generating Well-Shaped d-dimensional Delaunay Meshes, pp.245-267, 2003. ,
Diffusion maps and coarse-graining: a unified framework for dimensionality reduction, graph partitioning, and data set parameterization, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.28, issue.9, pp.1393-1403, 2006. ,
DOI : 10.1109/TPAMI.2006.184
Algebraic Topology : An Introduction, Graduate texts in Mathematics, vol.56, p.37, 1967. ,
Diffusion maps, spectral clustering and eigenfunctions of fokker-planck operators, Neural Information Processing Systems, 2005. ,
Finding the Homology of Submanifolds with High Confidence from??Random??Samples, Discrete & Computational Geometry, vol.33, issue.11, pp.419-441, 2008. ,
DOI : 10.1007/s00454-008-9053-2
Introduction to Piecewise-Linear Topology, p.33, 1972. ,
DOI : 10.1007/978-3-642-81735-9
Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.5500, pp.2323-2326, 2000. ,
DOI : 10.1126/science.290.5500.2323
Star splaying: An algorithm for repairing delaunay triangulations and convex hulls, Proc. ACM Symp. on Computational Geometry, pp.237-246, 2005. ,
COGNITION: The Manifold Ways of Perception, Science, vol.290, issue.5500, pp.2268-2269, 2000. ,
DOI : 10.1126/science.290.5500.2268
A Global Geometric Framework for Nonlinear Dimensionality Reduction, Science, vol.290, issue.5500, pp.2319-2323, 2000. ,
DOI : 10.1126/science.290.5500.2319
Geometric Integration Theory, p.35, 1957. ,
DOI : 10.1515/9781400877577
Seminar on Combinatorial Topology Institut des HautesÉtudesHautes´HautesÉtudes Scientifiques (Paris) and University of Warwick (Coventry), Notes Principal manifolds and nonlinear dimension reduction via local tangent space alignment, SIAM Journal of Scientific Computing, vol.26, issue.1 3, pp.33313-338, 1963. ,
