Certification of inequalities involving transcendental functions: combining SDP and max-plus approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of certifying an inequality of the form $f(x)\geq 0$, $\forall x\in K$, where $f$ is a multivariate transcendental function, and $K$ is a compact semialgebraic set. We introduce a certification method, combining semialgebraic optimization and max-plus approximation. We assume that $f$ is given by a syntaxic tree, the constituents of which involve semialgebraic operations as well as some transcendental functions like $\cos$, $\sin$, $\exp$, etc. We bound some of these constituents by suprema or infima of quadratic forms (max-plus approximation method, initially introduced in optimal control), leading to semialgebraic optimization problems which we solve by semidefinite relaxations. The max-plus approximation is iteratively refined and combined with branch and bound techniques to reduce the relaxation gap. Illustrative examples of application of this algorithm are provided, explaining how we solved tight inequalities issued from the Flyspeck project (one of the main purposes of which is to certify numerical inequalities used in the proof of the Kepler conjecture by Thomas Hales).
hal-00932348 , version 1 (16-01-2014)
Xavier Allamigeon, Stéphane Gaubert, Victor Magron, Benjamin Werner. Certification of inequalities involving transcendental functions: combining SDP and max-plus approximation. European Control Conference (ECC'13), Jul 2013, Zurich, Switzerland. pp.2244 - 2250. ⟨hal-00932348⟩
257 Consultations
0 Téléchargements
