Book sections
Comparing Two Discriminant Probabilistic Interestingness Measures for Association Rules
Abstract : Preliminary normalization is needed for probabilistic pairwise comparison between attributes in Data Mining. Normalization plays a very important part in preserving the discriminant property of the probability scale when the observation number becomes large. Asymmetrical associations between boolean attributes are considered in our paper. Its goal consists of comparison between two approaches. The first one is due to a normalized version of the "Likelihood Linkage Analysis" methodology. The second one is based on the notion of "Test Value" defined with respect to a hypothetical sample, sized 100 and summarizing the initial observed sample. Two facets are developed in our work: theoretical and experimental. A comparative experimental analysis is presented with the well known databases "Wages" and "Abalone".
Complete list of metadata
https://hal.inria.fr/hal-00932561
Contributor : Marie-Odile Cordier Connect in order to contact the contributor
Submitted on : Friday, January 17, 2014 - 12:43:33 PM
Last modification on : Thursday, October 21, 2021 - 3:33:38 AM
Links full text
Identifiers
Citation
Israël-César Lerman, Sylvie Guillaume. Comparing Two Discriminant Probabilistic Interestingness Measures for Association Rules. Fabrice Guillet and Bruno Pinaud and Gilles Venturini and Djamel Abdelkader Zighed. Advances in Knowledge Discovery and Management, 471, Springer, pp.59-83, 2013, Studies in Computatinal Intelligence, ⟨10.1007/978-3-642-35855-5_4⟩. ⟨hal-00932561⟩
Share
Metrics
Record views
259
