Empirical Studies in Information Visualization: Seven Scenarios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2012
Heidi Lam
  • Fonction : Auteur
  • PersonId : 928684
Enrico Bertini
  • Fonction : Auteur
  • PersonId : 928685
Petra Isenberg
Catherine Plaisant
  • Fonction : Auteur
  • PersonId : 928686
Sheelagh Carpendale
  • Fonction : Auteur
  • PersonId : 924126
We take a new, scenario based look at evaluation in information visualization. Our seven scenarios, evaluating visual data analysis and reasoning, evaluating user performance, evaluating user experience, evaluating environments and work practices, evaluating communication through visualization, evaluating visualization algorithms, and evaluating collaborative data analysis were derived through an extensive literature review of over 800 visualization publications. These scenarios distinguish different study goals and types of research questions and are illustrated through example studies. Through this broad survey and the distillation of these scenarios we make two contributions. One, we encapsulate the current practices in the information visualization research community and, two, we provide a different approach to reaching decisions about what might be the most effective evaluation of a given information visualization. Scenarios can be used to choose appropriate research questions and goals and the provided examples can be consulted for guidance on how to design one's own study.
Lam_2012_ESI.pdf (5.93 Mo) Télécharger le fichier
Format : Figure, Image
hal-00932606 , version 1 (17-01-2014)
Heidi Lam, Enrico Bertini, Petra Isenberg, Catherine Plaisant, Sheelagh Carpendale. Empirical Studies in Information Visualization: Seven Scenarios. IEEE Transactions on Visualization and Computer Graphics, 2012, 18 (9), pp.1520--1536. ⟨10.1109/TVCG.2011.279⟩. ⟨hal-00932606⟩
358 Consultations
6605 Téléchargements
