Fill-in reduction in sparse matrix factorizations using hypergraphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We discuss the use of hypergraph partitioning based methods in fill-reducing orderings of sparse matrices for Cholesky, LU and QR factorizations. For the Cholesky factorization, we investigate a recent result on pattern-wise decomposition of sparse matrices, generalize the result, and develop algorithmic tools to obtain more effective ordering methods. The generalized results help us formulate the fill-reducing ordering problem for LU factorization as we do for the Cholesky case, without ever symmetrizing the given matrix $A$ as $|A| + |A^T|$ or $|^AT ||A|$. For the QR factorization, we adopt a recently proposed technique to use hypergraph models in a fairly standard manner. The method again does not form the possibly much denser matrix $|A^T ||A|$. We also discuss alternatives for LU and QR factorization cases where the symmetrized matrix can be used. We provide comparisons with the most common alternatives in all three cases.
RR-8448.pdf (861.11 Ko) Télécharger le fichier
hal-00932882 , version 1 (30-04-2014)
hal-00932882 , version 2 (14-01-2021)
  • HAL Id : hal-00932882 , version 2
Oguz Kaya, Enver Kayaaslan, Bora Uçar, Iain S. Duff. Fill-in reduction in sparse matrix factorizations using hypergraphs. [Research Report] RR-8448, INRIA. 2014. ⟨hal-00932882v2⟩
475 Consultations
4797 Téléchargements
