Faster Compact Diffie-Hellman: Endomorphisms on the x-line - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We describe an implementation of fast elliptic curve scalar multiplication, optimized for Diffie--Hellman Key Exchange at the 128-bit security level. The algorithms are compact (using only x-coordinates), run in constant time with uniform execution patterns, and do not distinguish between the curve and its quadratic twist; they thus have a built-in measure of side-channel resistance. The core of our construction is a suite of two-dimensional differential addition chains driven by efficient endomorphism decompositions, built on curves selected from a family of Q-curve reductions over \(\FF_{p^2}\) with \(p = 2^{127}-1\). We include state-of-the-art experimental results for twist-secure, constant-time, x-coordinate-only scalar multiplication.
main.pdf (288.01 Ko) Télécharger le fichier
hal-00932952 , version 1 (18-01-2014)
Craig Costello, Huseyin Hisil, Benjamin Smith. Faster Compact Diffie-Hellman: Endomorphisms on the x-line. EUROCRYPT 2014, International Association for Cryptologic Research, May 2014, Copenhagen, Denmark. pp.183-200, ⟨10.1007/978-3-642-55220-5_11⟩. ⟨hal-00932952⟩
363 Consultations
380 Téléchargements
