Solitons and the Inverse Scattering Transform, Studies in Applied Mathematics. SIAM, issue.1, 2000. ,
DOI : 10.1137/1.9781611970883
Integrable Nonlinear Evolution Equations on a Finite Interval, Communications in Mathematical Physics, vol.263, issue.1, pp.133-172, 2006. ,
DOI : 10.1007/s00220-005-1495-2
Efficient non-linear model reduction via a least-squares Petrov-Galerkin projection and compressive tensor approximations, International Journal for Numerical Methods in Engineering, vol.35, issue.2, pp.155-181, 2011. ,
DOI : 10.1002/nme.3050
A dynamically bi-orthogonal method for time-dependent stochastic partial differential equations I: Derivation and algorithms, Journal of Computational Physics, vol.242, pp.843-868, 2013. ,
DOI : 10.1016/j.jcp.2013.02.033
A dynamically bi-orthogonal method for time-dependent stochastic partial differential equations II: Adaptivity and generalizations, Journal of Computational Physics, vol.242, pp.753-776, 2013. ,
DOI : 10.1016/j.jcp.2013.02.020
Inverse scattering on the line, Communications on Pure and Applied Mathematics, vol.45, issue.2, pp.121-251, 1979. ,
DOI : 10.1002/cpa.3160320202
Solitons: an introduction. Cambridge texts in Applied Mathematics, 1996. ,
Reduced-Order Modeling based on Approximated Lax Pairs, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00752810
Space-time finite element methods for elastodynamics: formulations and error estimates Computer methods in applied mechanics and engineering, pp.339-363, 1988. ,
Separation of arterial pressure into a nonlinear superposition of solitary waves and a windkessel flow, Biomedical Signal Processing and Control, vol.2, issue.3, pp.163-170, 2007. ,
DOI : 10.1016/j.bspc.2007.05.004
Analyse de signaux par quantification semi-classique. Application à l'analyse des signaux de pression artérielle, 2008. ,
URL : https://hal.archives-ouvertes.fr/tel-00357309
Arterial blood pressure analysis based on scattering transform II, 2007 29th Annual International Conference of the IEEE Engineering in Medicine and Biology Society, pp.5330-5333, 2007. ,
DOI : 10.1109/IEMBS.2007.4353545
URL : https://hal.archives-ouvertes.fr/inria-00139529
Semi-classical signal analysis, Mathematics of Control, Signals, and Systems, vol.7, issue.1, 2012. ,
DOI : 10.1007/s00498-012-0091-1
URL : https://hal.archives-ouvertes.fr/inria-00495965
Validation of a Semi-Classical Signal Analysis Method for Stroke Volume Variation Assessment: A Comparison with the PiCCO Technique, Annals of Biomedical Engineering, vol.74, issue.4, pp.383618-3629, 2010. ,
DOI : 10.1007/s10439-010-0118-z
URL : https://hal.archives-ouvertes.fr/inria-00527442
Integrals of nonlinear equations of evolution and solitary waves, Communications on Pure and Applied Mathematics, vol.15, issue.5, pp.467-490, 1968. ,
DOI : 10.1002/cpa.3160210503
The small dispersion limit of the Korteweg-de Vries equation. I, Communications on Pure and Applied Mathematics, vol.8, issue.3, pp.253-290, 1983. ,
DOI : 10.1002/cpa.3160360302
A reduced-basis element method, Comptes Rendus Mathematique, vol.335, issue.2, pp.447-459, 2002. ,
DOI : 10.1016/S1631-073X(02)02427-5
URL : https://hal.archives-ouvertes.fr/hal-00112608
A space-time discontinuous Galerkin method for the solution of the wave equation in the time domain, International Journal for Numerical Methods in Engineering, vol.29, issue.R2, pp.275-295, 2009. ,
DOI : 10.1002/nme.2485
Reduced basis approximation and a posteriori error estimation for affinely parametrized elliptic coercive partial differential equations, Archives of Computational Methods in Engineering, vol.40, issue.11, pp.1-47, 2007. ,
DOI : 10.1007/BF03024948
Multidimensional a priori hyper-reduction of mechanical models involving internal variables, Computer Methods in Applied Mechanics and Engineering, vol.225, issue.228, pp.28-43, 2012. ,
DOI : 10.1016/j.cma.2012.03.005
URL : https://hal.archives-ouvertes.fr/hal-00705783
Dynamically orthogonal field equations for continuous stochastic dynamical systems, Physica D: Nonlinear Phenomena, vol.238, issue.23-24, pp.2347-2360, 2009. ,
DOI : 10.1016/j.physd.2009.09.017
The semiclassical limit of the defocousing NLS hierarchy, Comm. Pure Appl. Math, vol.52, pp.613-654, 1999. ,
Low-dimensional description of complicated phenomena, Contemporary Mathematics, vol.99, pp.277-305, 1989. ,
DOI : 10.1090/conm/099/1034504
Space?time discontinuous galerkin finite element method with dynamic grid motion for inviscid compressible flows: I. general formulation, Journal of Computational Physics, vol.182, issue.2, pp.546-585, 2002. ,
