On seeing stuff: the perception of materials by humans and machines, Proceedings of SPIE, vol.4299, pp.1-12, 2001. ,
A precomputed polynomial representation for interactive BRDF editing with global illumination, ACM Transactions on Graphics, vol.27, issue.2, pp.1-13, 2008. ,
Real-time BRDF editing in complex lighting, In ACM Transactions on Graphics, vol.25, issue.2, p.945, 2006. ,
Trivial connections on discrete surfaces, Computer Graphics Forum (SGP), vol.29, issue.5 2, pp.1525-1533, 2010. ,
Imaging vector fields using line integral convolution, Proceedings of the 20th annual conference on Computer graphics and interactive techniques SIGGRAPH '93, pp.263-270, 1993. ,
Differential Geometry of Curves and Surfaces, p.9, 1976. ,
Realworld illumination and the perception of surface reflectance properties, Journal of Vision, vol.3, issue.1, pp.347-368, 2003. ,
Design of tangent vector fields, ACM Transactions on Graphics (TOG), issue.2, 2007. ,
Shading-based surface editing, ACM Transactions on Graphics (TOG), vol.2, issue.6, 2008. ,
Globally optimal direction fields, ACM Trans. Graph, vol.32, issue.5 6, 2013. ,
Specularities on surfaces with tangential hairs or grooves Specularities on Surfaces with Tangential Hairs or Grooves Illumination brush: Interactive design of all-frequency lighting, Proceedings of the Seventh IEEE International Conference on Computer Vision 320?335. 2, 3, 5, 7 [Nic77] NICODEMUS F.: Geometrical Considerations and Nomenclature for Reflectance. NBS Monograph. U.S. Government Printing Office Proceedings of the 15th Pacific Conference on Computer Graphics and Applications PG '07, pp.2-7, 1977. ,
Interactive reflection editing, ACM Trans. Graph, vol.28, issue.129 6, pp.51-129, 2009. ,
Theory for off-specular reflection from roughened surfaces, JOSA, issue.2, 1967. ,
Measuring and modeling anisotropic reflection, ACM SIGGRAPH Computer Graphics, vol.26, issue.5, pp.265-272, 1992. ,
Discrete line congruences for shading and lighting, Computer Graphics Forum, vol.325, issue.7, 2013. ,
Vector field design on surfaces, ACM Trans. Graph, vol.25, issue.4 2, pp.1294-1326, 2006. ,
