MPAgenomics : An R package for multi-patients analysis of genomic markers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
MPAgenomics, standing for multi-patients analysis (MPA) of genomic markers, is an R-package devoted to: (i) efficient segmentation, and (ii) genomic marker selection from multi-patient copy number and SNP data profiles. It provides wrappers from commonly used packages to facilitate their repeated (sometimes difficult) use, offering an easy-to-use pipeline for beginners in R. The segmentation of successive multiple profiles (finding losses and gains) is based on a new automatic choice of influential parameters since default ones were misleading in the original packages. Considering multiple profiles in the same time, MPAgenomics wraps efficient penalized regression methods to select relevant markers associated with a given response.
MPAgenomics_hal.pdf (129.72 Ko) Télécharger le fichier
hal-00933614 , version 1 (20-01-2014)
hal-00933614 , version 2 (10-12-2014)
hal-00933614 , version 3 (14-01-2015)
Quentin Grimonprez, Alain Celisse, Samuel Blanck, Meyling Cheok, Martin Figeac, et al.. MPAgenomics : An R package for multi-patients analysis of genomic markers. 2014. ⟨hal-00933614v2⟩
697 Consultations
807 Téléchargements
