Single nucleotide polymorphism arrays: a decade of biological, computational and technological advances, Nucleic Acids Research, vol.37, issue.13, pp.4181-4193, 2009. ,
DOI : 10.1093/nar/gkp552
aroma.affymetrix: A generic framework in R for analyzing small to very large Affymetrix data sets in bounded memory, 2008. ,
Changepoint: An R Package for Changepoint Analysis, 2013. ,
CGHcall: Calling Aberrations for Array CGH Tumor Profiles. 2012. R package version 2.20 ,
Regularization Paths for Generalized Linear Models via Coordinate Descent, Journal of Statistical Software, vol.33, issue.1, pp.1-22, 2010. ,
DOI : 10.18637/jss.v033.i01
R: A Language and Environment for Statistical Computing. Vienna, Austria: R Foundation for Statistical Computing ,
TumorBoost: Normalization of allele-specific tumor copy numbers from a single pair of tumor-normal genotyping microarrays, BMC Bioinformatics, vol.11, issue.1, p.245, 2010. ,
DOI : 10.1186/1471-2105-11-245
URL : https://hal.archives-ouvertes.fr/hal-01199777
A single-array preprocessing method for estimating full-resolution raw copy numbers from all Affymetrix genotyping arrays including GenomeWideSNP 5 & 6, Bioinformatics, vol.25, issue.17, pp.252149-2156, 2009. ,
DOI : 10.1093/bioinformatics/btp371
Learning smoothing models of copy number profiles using breakpoint annotations, BMC Bioinformatics, vol.14, issue.1, p.164, 2013. ,
DOI : 10.1186/gb-2004-5-10-r80
URL : https://hal.archives-ouvertes.fr/hal-00663790
A statistical approach for array CGH data analysis, BMC Bioinformatics, vol.6, issue.1, p.27, 2005. ,
DOI : 10.1186/1471-2105-6-27
URL : https://hal.archives-ouvertes.fr/hal-00427846
Pruned dynamic programming for optimal multiple change-point detection. arXiv e-print, 2010. ,
Optimal Detection of Changepoints With a Linear Computational Cost, Journal of the American Statistical Association, vol.63, issue.500, pp.1590-1598 ,
DOI : 10.1080/01621459.2012.737745
Detecting multiple change-points in the mean of gaussian process by model selection. Signal Process, pp.717-736, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00071847
Minimal penalties for gaussian model selection. Probability Theory Related Fields, pp.33-73, 2007. ,
Segmentation-based detection of allelic imbalance and loss-of-heterozygosity in cancer cells using whole genome SNP arrays, Genome Biology, vol.9, issue.9, p.136, 2008. ,
DOI : 10.1186/gb-2008-9-9-r136
CGHcall: calling aberrations for array CGH tumor profiles, Bioinformatics, vol.23, issue.7, pp.892-894, 2007. ,
DOI : 10.1093/bioinformatics/btm030
Regression shrinkage and selection via the lasso, J R Stat Soci Series B, vol.58, pp.267-288, 1994. ,
Least angle regression, Ann Stat, vol.32, pp.407-499, 2004. ,
High-dimensional covariance estimation by minimizing ???1-penalized log-determinant divergence, Electronic Journal of Statistics, vol.5, issue.0, pp.935-980, 2011. ,
DOI : 10.1214/11-EJS631
Spike and slab variable selection: Frequentist and Bayesian strategies, The Annals of Statistics, vol.33, issue.2, pp.730-773, 2005. ,
DOI : 10.1214/009053604000001147
Generalized ridge regression: geometry and computational solutions when p is larger than n, 2010. ,
A survey of cross-validation procedures for model selection, Statistics Surveys, vol.4, issue.0, pp.40-79, 2010. ,
DOI : 10.1214/09-SS054
URL : https://hal.archives-ouvertes.fr/hal-00407906
THE TRANSFORMATION OF POISSON, BINOMIAL AND NEGATIVE-BINOMIAL DATA, Biometrika, vol.35, issue.3-4, pp.246-254, 1948. ,
DOI : 10.1093/biomet/35.3-4.246
