New interface
Conference papers
Symmetrized summation polynomials: using small order torsion points to speed up elliptic curve index calculus
Abstract : Decomposition-based index calculus methods are currently efficient only for elliptic curves E defined over non-prime finite fields of very small extension degree n. This corresponds to the fact that the Semaev summation polynomials, which encode the relation search (or “sieving”), grow over-exponentially with n. Actually, even their computation is a first stumbling block and the largest Semaev polynomial ever computed is the 6-th. Following ideas from Faugère, Gaudry, Huot and Renault, our goal is to use the existence of small order torsion points on E to define new summation polynomials whose symmetrized expressions are much more compact and easier to compute. This setting allows to consider smaller factor bases, and the high sparsity of the new summation polynomials provides a very efficient decomposition step. In this paper the focus is on 2-torsion points, as it is the most important case in practice. We obtain records of two kinds: we successfully compute up to the 8-th symmetrized summation polynomial and give new timings for the computation of relations with degree 5 extension fields.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-00935050
Contributor : Guénaël Renault Connect in order to contact the contributor
Submitted on : Tuesday, December 30, 2014 - 2:09:50 PM
Last modification on : Friday, January 21, 2022 - 3:21:49 AM
Long-term archiving on: : Saturday, April 15, 2017 - 11:55:13 AM
File
Semaev2torsion.pdf
Identifiers
Citation
Jean-Charles Faugère, Louise Huot, Antoine Joux, Guénaël Renault, Vanessa Vitse. Symmetrized summation polynomials: using small order torsion points to speed up elliptic curve index calculus. EUROCRYPT 2014 - 33rd Annual International Conference on the Theory and Applications of Cryptographic Techniques, May 2014, Copenhagen, Denmark. pp.40-57, ⟨10.1007/978-3-642-55220-5_3⟩. ⟨hal-00935050⟩
Share
Metrics
Record views
376
Files downloads
292
