High Order Sonic Boom Modeling by Adaptive Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2010
This paper presents an accurate approach to simulate the sonic boom of supersonic aircrafts. The near-field flow is modeled by the conservative Euler equations and is solved using a vertex-centered finite volume approach on adapted unstructured tetrahedral meshes. A metric-based anisotropic mesh adaptation is considered to control the interpolation error in Lp norm. Then, from the CFD solution, the pressure distribution under the aircraft is extracted and used to set up the initial conditions of the propagation algorithm in the far-field. The pressure distribution is propagated down to the ground in order to obtain the sonic boom signature using a ray tracing algorithm based upon the Thomas waveform parameter method. In this study, a sonic boom sensitivity analysis is carried out on several aircraft designs (low-drag and low-boom shapes).
hal-00935285 , version 1 (23-01-2014)
F. Alauzet, Adrien Loseille. High Order Sonic Boom Modeling by Adaptive Methods. Journal of Computational Physics, 2010, 229, pp.561-593. ⟨10.1016/j.jcp.2009.09.020⟩. ⟨hal-00935285⟩
68 Consultations
0 Téléchargements
