Nonlinear Multiobjective Optimization Multiobjective Evolutionary Algorithms: a Comparative Case Study and the Strength Pareto Approach Comparison of Multiobjective Evolutionary Algorithms: Empirical Results Multiobjective Optimization and Multiple Constraint Handling with Evolutionary Algorithms in a Unified Formulation Approximating the Nondominated Front Using the Pareto Archived Evolution Strategy An Evolutionary Algorithm for Multiobjective Optimization: The Strength Pareto Approach A Fast and Elitist Multiobjective Genetic Algorithm: NSGA-II, Structural and Multidisciplinary Optimization Swiss Federal Institute of Technology (ETH) Zurich Multi-objective Optimization using Genetic Algorithms: a Tutorial, pp.369-395, 1998. ,
Cooperation and Competition in Multidisciplinary Optimization -Application to the aero-structural aircraft wing shape optimization Multiple-Gradient Descent Algorithm (MGDA) " . INRIA RR 6953 Comparison between MGDA and PAES for Multi-Objective Optimization Inria technical report RR-7667 Application of Metamodel-Assisted Multiple-Gradient Descent Algorithm (MGDA) to Air-Cooling Duct Shape Optimization CONMIN -A FORTRAN Program for Constrained Function Minimization: User's Manual Non-cooperative Games Combining Game Theory and Genetic Algorithms with Application to DDM-nozzle Optimization Problems Finite Elements in Analysis and Design 37 Split of Territories A Direct Search Optimization Method that Models the Objective and Constraint Functions by Linear Interpolation A Simplex Method for Function Minimization The Challenges of Defining an Acceptable Sonic Boom Overland, Multicriterion Aerodynamic Shape Design Optimization and Inverse Problems Using Control Theory and Nash Games Advances in Optimization and Numerical Analysis Supersonic Vehicle Systems for the 2020 to 2035 Timeframe High-Speed Research: Sonic Boom NASA CP-3172 High-Speed Research: Sonic Boom NASA CP-3173, pp.9921007-599, 1951. ,
The Flow Pattern of a Supersonic Projectile Lower Bounds for Sonic Boom Considering the Negative Overpressure Region Lower Bounds for Sonic Booms in the Midfield Sonic-Boom Minimisation Sonic-Boom Minimization With Nose-Bluntness Relaxation Sonic Boom Minimization Using Inverse Design and Probabilistic Acoustic Propagation Generalized Formulation and Extension of Sonic Boom Minimization Theory for Front and Aft Shaping Origins and Overview of the Shaped Sonic Boom Demonstration Program AIAA Paper 2005-5, 43rd AIAA Aerospace Sciences Meeting and Exhibit D-SEND Project for Low Sonic Boom Design Technology Limitations of Linear Theory for Sonic Boom Calculations Multifidelity Design Optimization of Low-Boom Supersonic Jets Advanced Optimization Approach for Supersonic Low-Boom Design Extrapolation of Sonic Boom Signatures from CFD Solution Impact of Multipole Matching Resolution on Supersonic Aircraft Sonic Boom Assesment An Efficient Object-Oriented Solution to CFD Complexity CFD Analysis of Nozzle Jet Plume Effects on Sonic Boom Signature Approximate Riemann Solvers, Parameter Vectors and Difference Schemes On Finite-Difference Approximations and Entropy Conditions for Shocks The TRAPS Sonic Boom Program Completely Derandomized Self-Adaptation in Evolution Strategies Practical Optimization Self-Organized Formation of Topologically Correct Feature Maps, Lower Bounds for the Pressure Jumps of the Shock Waves of a Supersonic Transport of Given Length ICAS 2012, 28th International Congress of the Aeronautical Sciences proceedings of 4th EUCASS.W., " A Comparative Study of Computational Methods in Cosmic Gas Dynamics, pp.301-348, 1052. ,
