Multidimensional stochastic differential equations with distributional drift - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Franco Flandoli
  • Fonction : Auteur
  • PersonId : 951480
Elena Issoglio
  • Fonction : Auteur
  • PersonId : 951481
Francesco Russo
This paper investigates a time-dependent multidimensional stochastic differential equation with drift being a distribution in a suitable class of Sobolev spaces with negative derivation order. This is done through a careful analysis of the corresponding Kolmogorov equation whose coefficient is a distribution.
singulardrift2014-01-23FINALE.pdf (208.1 Ko) Télécharger le fichier
hal-00935399 , version 1 (23-01-2014)
hal-00935399 , version 2 (29-07-2015)
Franco Flandoli, Elena Issoglio, Francesco Russo. Multidimensional stochastic differential equations with distributional drift. 2014. ⟨hal-00935399v1⟩
Collections
PARISTECH
272 Consultations
2413 Téléchargements
