Error estimation and anisotropic mesh refinement for 3d laminar aerodynamic flow simulations A multiple grid scheme for solving the Euler equations 18 H. Nishikawa. A first-order system approach for diffusion equation. I: Second-order residual-distribution scheme 19 H. Nishikawa. A first-order system approach for diffusion equation. II: Unification of advection and diffusion 20 H. Nishikawa. Robust and accurate viscous discretization via upwind scheme I: Basic principle On high-order fluctuation-splitting schemes for Navier?Stokes equations, tional Physics 5th Computational Fluid Dynamics Conference Computational Fluid Dynamics 2004: Proceedings of the Third International Conference on Computational Fluid Dynamics 22 H.Pailì ere, J. Boxho, G. Degrez, and H. Deconinck. Multidimensional upwind residual distribution schemes for the convection-diffusion equation, pp.357-3977344, 1981. ,
On uniformly high-order accurate residual distribution schemes for advection-diffusion Verification of euler/navierstokes codes using the method of manufactured solutions Fluctuation splitting schemes for the 2d Euler equations In Von Karman Institute for Fluid Mechanics Lecture Series on Computational Fluid Mechanics Efficient implicit non-linear lu-sgs approach for compressible flow computation using high-order spectral difference method A parallel, implicit, multi-dimensional upwind, residual distribution method for the Navier-Stokes equations on unstructured grids A simple error estimator and adaptive procedure for practical engineerng analysis, O.C. Zienkiewicz and R.L.Taylor. Finite Element Method, pp.547-556599, 1987. ,
