Polymers in 2D Turbulence: Suppression of Large Scale Fluctuations, Physical Review Letters, vol.11, issue.10, p.104502, 2002. ,
DOI : 10.1063/1.870100
URL : https://hal.archives-ouvertes.fr/hal-01550818
A penalization method to take into account obstacles in incompressible viscous flows, Numerische Mathematik, vol.81, issue.4, pp.497-520, 1999. ,
DOI : 10.1007/s002110050401
Viscoelastic flow past a confined cylinder of a low density polyethylene melt, Journal of Non-Newtonian Fluid Mechanics, vol.68, issue.2-3, pp.173-203, 1997. ,
DOI : 10.1016/S0377-0257(96)01519-4
New efficient boundary conditions for incompressible Navier-Stokes equations : a well-posedness result, ESAIM: Mathematical Modelling and Numerical Analysis, vol.30, issue.7, pp.2-30, 1996. ,
DOI : 10.1051/m2an/1996300708151
URL : http://www.esaim-m2an.org/articles/m2an/pdf/1996/07/m2an1996300708151.pdf
Numerical study of grid turbulence in two dimensions and comparison with experiments on turbulent soap films, Physical Review E, vol.74, issue.2, p.1165, 1999. ,
DOI : 10.1103/PhysRevLett.74.3800
URL : https://hal.archives-ouvertes.fr/hal-01550410
Experiments and direct numerical simulations of two-dimensional turbulence, Physical Review E, vol.1, issue.4, p.46305, 2005. ,
DOI : 10.1103/PhysRevLett.90.104502
URL : https://hal.archives-ouvertes.fr/hal-01552724
The 2D lid-driven cavity problem revisited, Computers & Fluids, vol.35, issue.3, pp.326-348, 2006. ,
DOI : 10.1016/j.compfluid.2004.12.004
URL : https://hal.archives-ouvertes.fr/hal-00281918
Experimental characterization of viscoelastic effects on two- and three-dimensional shear instabilities, Journal of Fluid Mechanics, vol.416, pp.151-172, 2000. ,
DOI : 10.1017/S0022112000008818
Shear instability inhibition in a cylinder wake by local injection of a viscoelastic fluid, Physics of Fluids, vol.11, issue.2, pp.494-496, 1999. ,
DOI : 10.1063/1.869532
Highly parallel time integration of viscoelastic flows, Journal of Non-Newtonian Fluid Mechanics, vol.100, issue.1-3, pp.191-216, 2001. ,
DOI : 10.1016/S0377-0257(01)00136-7
Creeping flow of dilute polymer solutions past cylinders and spheres, Journal of Non-Newtonian Fluid Mechanics, vol.29, pp.381-432, 1988. ,
DOI : 10.1016/0377-0257(88)85062-6
Simulation of the flow of a viscoelastic fluid around a stationary cylinder using an extended finite element method, Computers & Fluids, vol.57, pp.183-194, 2012. ,
DOI : 10.1016/j.compfluid.2011.12.020
Modification of a vortex street by a polymer additive, Physics of Fluids, vol.28, issue.4, pp.867-871, 2001. ,
DOI : 10.1252/jcej.13.77
The flow of an Oldroyd-B fluid past a cylinder in a channel: adaptive viscosity vorticity (DAVSS-??) formulation, Journal of Non-Newtonian Fluid Mechanics, vol.87, issue.1, pp.47-73, 1999. ,
DOI : 10.1016/S0377-0257(99)00006-3
Galerkin/least-square finite-element methods for steady viscoelastic flows, Journal of Non-Newtonian Fluid Mechanics, vol.84, issue.2-3, pp.233-256, 1999. ,
DOI : 10.1016/S0377-0257(98)00154-2
Drag Enhancement with Polymers, Physical Review Letters, vol.100, issue.1, p.18302, 2008. ,
DOI : 10.1007/s003480050017
URL : https://hal.archives-ouvertes.fr/hal-00747122
Elastic turbulence in a polymer solution flow, Nature, vol.405, issue.6782, pp.53-55, 2000. ,
DOI : 10.1038/35011019
Elastic turbulence in curvilinear flows of polymer solutions, New Journal of Physics, vol.6, issue.29, 2004. ,
DOI : 10.1088/1367-2630/6/1/029
Wall effects on the flow of viscoelastic fluids around a circular cylinder, Journal of Non-Newtonian Fluid Mechanics, vol.60, issue.2-3, pp.179-198, 1995. ,
DOI : 10.1016/0377-0257(95)01394-2
Viscoelastic flow between eccentric rotating cylinders: unstructured control volume method, Journal of Non-Newtonian Fluid Mechanics, vol.64, issue.1, pp.71-92, 1996. ,
DOI : 10.1016/0377-0257(96)01429-2
31. Flow visualization of a two dimensional soap film flow over a cylinder at Re ffi, 2000. ,
Flow of viscoelastic fluids past a cylinder at high Weissenberg number: Stabilized simulations using matrix logarithms, Journal of Non-Newtonian Fluid Mechanics, vol.127, issue.1, pp.27-39, 2005. ,
DOI : 10.1016/j.jnnfm.2005.01.002
Boger Fluids, Annual Review of Fluid Mechanics, vol.41, issue.1, pp.129-142, 2009. ,
DOI : 10.1146/annurev.fluid.010908.165125
The laminar flow of dilute polymer solutions around circular cylinders, Journal of Fluid Mechanics, vol.4, issue.02, pp.269-288, 1970. ,
DOI : 10.1002/aic.690120507
An experimental investigation of viscoelatic flow past a circular cylinder, Bull, JSME, vol.36, pp.529-536, 1983. ,
Polymers suppress the inverse transfers of energy and the enstrophy flux fluctuations in two-dimensional turbulence, Physical Review E, vol.69, issue.3, p.36310, 2004. ,
DOI : 10.1103/PhysRevLett.86.3558
URL : https://hal.archives-ouvertes.fr/hal-01551884
Probability Density Functions of the Enstrophy Flux in Two Dimensional Grid Turbulence, Physical Review Letters, vol.81, issue.8, pp.1696-1699, 2000. ,
DOI : 10.1103/PhysRevLett.81.1417
URL : https://hal.archives-ouvertes.fr/hal-01550476
Two-dimensional turbulence: a review of some recent experiments, Reports on Progress in Physics, vol.65, issue.5, pp.845-894, 2002. ,
DOI : 10.1088/0034-4885/65/5/204
URL : https://hal.archives-ouvertes.fr/hal-01550779
Experiments with Turbulent Soap Films, Physical Review Letters, vol.68, issue.20, pp.3975-3978, 1995. ,
DOI : 10.1103/PhysRevLett.68.938
URL : https://hal.archives-ouvertes.fr/hal-01556614
Vorticity Measurements in Turbulent Soap Films, Physical Review Letters, vol.19, issue.2, pp.277-280, 1998. ,
DOI : 10.1016/0377-0265(93)90040-E
URL : https://hal.archives-ouvertes.fr/hal-01550235
Viscoelastic flow of polymer solutions around a periodic, linear array of cylinders: comparisons of predictions for microstructure and flow fields, Journal of Non-Newtonian Fluid Mechanics, vol.77, issue.3, pp.77-153, 1998. ,
DOI : 10.1016/S0377-0257(97)00067-0
Drag Reduction by Additives, Annual Review of Fluid Mechanics, vol.1, issue.1, pp.367-384, 1969. ,
DOI : 10.1146/annurev.fl.01.010169.002055
A spectral vanishing viscosity method for stabilizing viscoelastic flows, Journal of Non-Newtonian Fluid Mechanics, vol.115, issue.2-3, pp.125-155, 2003. ,
DOI : 10.1016/S0377-0257(03)00172-1
The Wake Instability in Viscoelastic Flow past Confined Circular Cylinders, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.344, issue.1671, pp.344-265, 1993. ,
DOI : 10.1098/rsta.1993.0091
Maximum drag reduction in a turbulent channel flow by polymer additives, Journal of Fluid Mechanics, vol.492, pp.91-100, 2003. ,
DOI : 10.1017/S0022112003005597
Numerical simulation of confined flow of polyethylene melts around a cylinder in a planar channel1Dedicated to the memory of Professor Gianni Astarita.1, Journal of Non-Newtonian Fluid Mechanics, vol.76, issue.1-3, pp.327-350, 1998. ,
DOI : 10.1016/S0377-0257(97)00125-0
Polymer-induced vortex modification in decaying two-dimensional turbulence, Physica A: Statistical Mechanics and its Applications, vol.258, issue.3-4, pp.329-340, 1998. ,
DOI : 10.1016/S0378-4371(98)00251-9
On the Formulation of Rheological Equations of State, Proc. R. Soc. Lond. A, pp.523-541, 1950. ,
DOI : 10.1098/rspa.1950.0035
A numerical study of steady and unsteady viscoelastic flow past bounded cylinders, Journal of Non-Newtonian Fluid Mechanics, vol.127, issue.1, pp.51-66, 2005. ,
DOI : 10.1016/j.jnnfm.2005.02.003
Method for time-dependent simulations of viscoelastic flows: vortex shedding behind cylinder, Journal of Non-Newtonian Fluid Mechanics, vol.101, issue.1-3, pp.113-137, 2001. ,
DOI : 10.1016/S0377-0257(01)00146-X
A locally-upwinded spectral technique (LUST) for viscoelastic flows, Journal of Non-Newtonian Fluid Mechanics, vol.108, issue.1-3, pp.49-71, 2002. ,
DOI : 10.1016/S0377-0257(02)00124-6
Vortex shedding in flows of dilute polymer solutions, Journal of Non-Newtonian Fluid Mechanics, vol.139, issue.1-2, pp.4-67, 2006. ,
DOI : 10.1016/j.jnnfm.2006.07.003
Simulations of three-dimensional viscoelastic flows past a circular cylinder at moderate Reynolds numbers, Journal of Fluid Mechanics, vol.67, pp.415-442, 2010. ,
DOI : 10.1017/S0022112096008750
Effects of viscoelasticity in the high Reynolds number cylinder wake, Journal of Fluid Mechanics, vol.121, pp.297-318, 2012. ,
DOI : 10.1063/1.870318
On the effects of viscoelasticity on two-dimensional vortex dynamics in the cylinder wake, Journal of Non-Newtonian Fluid Mechanics, vol.123, issue.2-3, pp.121-139, 2004. ,
DOI : 10.1016/j.jnnfm.2004.08.002
Hydroelastic instabilities in viscoelastic flow past a cylinder confined in a channel, Experiments in Fluids, vol.28, issue.2, pp.128-142, 2000. ,
Flow past a cylinder: shear layer instability and drag crisis, International Journal for Numerical Methods in Fluids, vol.7, issue.68, pp.75-98, 2005. ,
DOI : 10.1017/CBO9780511608803
URL : http://home.iitk.ac.in/%7Esmittal/publi_%26_present/sm_journals/drag_crisis.pdf
Finite element method for viscoelastic flows based on the discrete adaptive viscoelastic stress splitting and the discontinuous Galerkin method: DAVSS-G/DG, Journal of Non-Newtonian Fluid Mechanics, vol.86, issue.3, pp.86-281, 1999. ,
DOI : 10.1016/S0377-0257(98)00176-1
Effect of artificial stress diffusivity on the stability of numerical calculations and the flow dynamics of time-dependent viscoelastic flows, Journal of Non-Newtonian Fluid Mechanics, vol.60, issue.1, pp.60-53, 1995. ,
DOI : 10.1016/0377-0257(95)01377-8
Some observation on the flow of linear polymer solutions through straight tubes at large Reynolds number, Proceedings of the First International Congress of Rheology, pp.135-141, 1949. ,
Drag reduction in rough pipes, Journal of Fluid Mechanics, vol.35, issue.02, pp.225-246, 1970. ,
DOI : 10.2118/867-PA
Visco-elastic flow past circular cylinders mounted in a channel: experimental measurements of velocity and drag, Journal of Non-Newtonian Fluid Mechanics, vol.116, issue.2-3, pp.301-328, 2004. ,
DOI : 10.1016/j.jnnfm.2003.08.006
Vortex Dynamics in the Cylinder Wake, Annual Review of Fluid Mechanics, vol.28, issue.1, pp.477-539, 1996. ,
DOI : 10.1146/annurev.fl.28.010196.002401
Drag enhancement and drag reduction in viscoelastic fluid flow around a cylinder, EPL (Europhysics Letters), vol.91, issue.6, p.91, 2010. ,
DOI : 10.1209/0295-5075/91/64001
URL : https://hal.archives-ouvertes.fr/inria-00546810
Direct numerical simulations of 2D channel flows in the presence of polymers, EPL (Europhysics Letters), vol.95, issue.6, p.95, 2011. ,
DOI : 10.1209/0295-5075/95/64003
