Dictionary-Ontology Cross-Enrichment Using TLFi and WOLF to enrich one another - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It has been known since Ide and Veronis that it is impossible to automatically extract an ontology structure from a dictionary, because that information is simply not present. We at- tempt to extract structure elements from a dictionary using clues taken from a formal ontology, and use these elements to match dictionary definitions to ontology synsets; this allows us to enrich the ontology with dictionary definitions, assign ontological structure to the dictionary, and disambiguate elements of definitions and synsets.
W12-5107.pdf (144.52 Ko) Télécharger le fichier
hal-00936500 , version 1 (26-01-2014)
  • HAL Id : hal-00936500 , version 1
Emmanuel Eckard, Lucie Barque, Alexis Nasr, Benoît Sagot. Dictionary-Ontology Cross-Enrichment Using TLFi and WOLF to enrich one another. CogALex-III - 3rd Workshop on Cognitive Aspects of the Lexicon, Dec 2012, Mumbai, India. ⟨hal-00936500⟩
696 Consultations
336 Téléchargements
