New interface
Journal articles
The Factorization Method for a Cavity in an Inhomogeneous Medium
Shixu Meng 1 Houssem Haddar 2 Fioralba Cakoni 1
2 DeFI - Shape reconstruction and identification
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : We consider the inverse scattering problem for a cavity that is bounded by a penetrable anisotropic inhomogeneous medium of compact support and seek to determine the shape of the cavity from internal measurements on a curve or surface inside the cavity. We derive a factorization method which provides a rigorous characterization of the support of the cavity in terms of the range of an operator which is computable from the measured data. The support of the cavity is determined without a-priori knowledge of the constitutive parameters of the surrounding anisotropic medium provided they satisfy appropriate physical as well as mathematical assumptions imposed by our analysis. Numerical examples are given showing the viability of our method.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00936557
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Sunday, January 26, 2014 - 11:05:59 PM
Last modification on : Friday, November 18, 2022 - 9:24:28 AM
Identifiers
Collections
Citation
Shixu Meng, Houssem Haddar, Fioralba Cakoni. The Factorization Method for a Cavity in an Inhomogeneous Medium. Inverse Problems, 2014, 30 (045008), ⟨10.1088/0266-5611/30/4/045008⟩. ⟨hal-00936557⟩
Share
Metrics
Record views
267
