New interface
Conference papers
Compilation for heterogeneous SoCs : bridging the gap between software and target-specific mechanisms
Abstract : Current applications constraints are pushing for higher computation power while reducing energy consumption, driving the development of increasingly specialized socs. In the mean time, these socs are still programmed in assembly language to make use of their specific hardware mechanisms. The constraints on hardware development bringing specialization, hence heterogeneity, it is essential to support these new mechanisms using high-level programming. In this work, we use a parametric data flow formalism to abstract the application from any hardware platform. From this premise, we propose to contribute to the compilation of target independent programs on heterogeneous platforms. These developments are threefold, with 1) the support of hardware accelerators for computation using actor fusion, 2) the automatic generation of communications on complex memory layouts and 3) the synchronization of distributed cores using hardware mechanisms for scheduling. The code generation is illustrated on a telecommunication dedicated heterogeneous soc.
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-00936924
Contributor : Mickaël Dardaillon Connect in order to contact the contributor
Submitted on : Monday, January 27, 2014 - 3:37:49 PM
Last modification on : Wednesday, March 9, 2022 - 3:29:14 PM
Long-term archiving on: : Sunday, April 27, 2014 - 10:55:32 PM
File
hip3es_submission_1.pdf
Identifiers
  • HAL Id : hal-00936924, version 1
Collections
Citation
Mickaël Dardaillon, Kevin Marquet, Tanguy Risset, Jerome Martin, Henri-Pierre Charles. Compilation for heterogeneous SoCs : bridging the gap between software and target-specific mechanisms. workshop on High Performance Energy Efficient Embedded Systems - HIPEAC, Jan 2014, Vienne, Austria. ⟨hal-00936924⟩
Share
Metrics
Record views
315
Files downloads
208
