New interface
Journal articles
A Multi-Focused Proof System Isomorphic to Expansion Proofs
Kaustuv Chaudhuri 1 Stefan Hetzl 1 Dale Miller 1, 2
1 PARSIFAL - Proof search and reasoning with logic specifications
LIX - Laboratoire d'informatique de l'École polytechnique [Palaiseau], Inria Saclay - Ile de France
Abstract : The sequent calculus is often criticized for requiring proofs to contain large amounts of low-level syntactic details that can obscure the essence of a given proof. Because each inference rule introduces only a single connective, sequent proofs can separate closely related steps---such as instantiating a block of quantifiers---by irrelevant noise. Moreover, the sequential nature of sequent proofs forces proof steps that are syntactically non-interfering and permutable to nevertheless be written in some arbitrary order. The sequent calculus thus lacks a notion of canonicity: proofs that should be considered essentially the same may not have a common syntactic form. To fix this problem, many researchers have proposed replacing the sequent calculus with proof structures that are more parallel or geometric. Proof-nets, matings, and atomic flows are examples of such revolutionary formalisms. We propose, instead, an evolutionary approach to recover canonicity within the sequent calculus, which we illustrate for classical first-order logic. The essential element of our approach is the use of a multi-focused sequent calculus as the means for abstracting away low-level details from classical cut-free sequent proofs. We show that, among the multi-focused proofs, the maximally multi-focused proofs that collect together all possible parallel foci are canonical. Moreover, if we start with a certain focused sequent proof system, such proofs are isomorphic to expansion proofs---a well known, minimalistic, and parallel generalization of Herbrand disjunctions---for classical first-order logic. This technique appears to be a systematic way to recover the "essence of proof" from within sequent calculus proofs.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00937056
Contributor : Kaustuv Chaudhuri Connect in order to contact the contributor
Submitted on : Monday, January 27, 2014 - 4:58:39 PM
Last modification on : Thursday, January 20, 2022 - 5:30:45 PM
Long-term archiving on: : Sunday, April 27, 2014 - 11:45:12 PM
lkfexp.pdf
Identifiers
  • HAL Id : hal-00937056, version 1
Collections
Citation
Kaustuv Chaudhuri, Stefan Hetzl, Dale Miller. A Multi-Focused Proof System Isomorphic to Expansion Proofs. Journal of Logic and Computation, 2014. ⟨hal-00937056⟩
Share
Metrics
Record views
253
Files downloads
245
