Strongly oscillating singularities for the interior transmission eigenvalue problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2013
In this paper, we investigate a two-dimensional interior transmission eigenvalue problem for an inclusion made of a composite material. We consider configurations where the difference between the parameters of the composite material and those of the background changes sign on the boundary of the inclusion. In a first step, under some assumptions on the parameters, we extend the variational approach of the T-coercivity to prove that the transmission eigenvalues form at most a discrete set. In the process, we also provide localization results. Then, we study what happens when these assumptions are not satisfied. The main idea is that, due to very strong singularities that can occur at the boundary, the problem may lose Fredholmness in the natural H1 framework. Using Kondratiev theory, we propose a new functional framework where the Fredholm property is restored.
Fichier non déposé
hal-00937690 , version 1 (28-01-2014)
Anne-Sophie Bonnet-Ben Dhia, Lucas Chesnel. Strongly oscillating singularities for the interior transmission eigenvalue problem. Inverse Problems, 2013, 19(10), pp.104004. ⟨10.1088/0266-5611/29/10/104004⟩. ⟨hal-00937690⟩
224 Consultations
0 Téléchargements
