Numerical Microlocal analysis of 2-D noisy harmonic plane and circular waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 2013
We present a mathematical and numerical analysis of the stability and accuracy of the NMLA (Numerical MicroLocal Analysis) method [J. Comput. Phys. 199(2) (2004), 717-741] and its discretization.We restrict to homogeneous space and focus on the two simplest cases: (1) Noisy plane wave packets, (2) Noisy point source solutions. A stability result is obtained through the introduction of a new "impedance" observable. The analysis of the point source case leads to a modified second order (curvature dependent) correction of the algorithm. Since NMLA is local, this second order improved version can be applied to general data (heterogeneous media). See [J. Comput. Phys. 231(14) (2012), 4643-4661] for a an application to a source discovery inverse problem.
Fichier non déposé
hal-00937691 , version 1 (28-01-2014)
Jean-David Benamou, Francis Collino, Simon Marmorat. Numerical Microlocal analysis of 2-D noisy harmonic plane and circular waves. Asymptotic Analysis, 2013, 83 (1-2), pp.157--187. ⟨10.3233/ASY-121157⟩. ⟨hal-00937691⟩
223 Consultations
0 Téléchargements
