A review of Gaussian random fields and correlation functions, 1997. ,
THE TRANSFORMATION OF POISSON, BINOMIAL AND NEGATIVE-BINOMIAL DATA, Biometrika, vol.35, issue.3-4, pp.246-254, 1948. ,
DOI : 10.1093/biomet/35.3-4.246
A Procedure for Accurate One-Dimensional Strain Measurement Using the Grid Method, Experimental Mechanics, vol.29, issue.7???8, pp.841-854, 2009. ,
DOI : 10.1007/s11340-008-9203-8
Investigation of the grid method for accurate in-plane strain measurement, Measurement Science and Technology, vol.20, issue.9, p.95102, 2009. ,
DOI : 10.1088/0957-0233/20/9/095102
An adaptive statistical method for 4d-fluorescence image sequence denoising with spatio-temporal discontinuities preserving, Biophotonics for Life Sciences and Medicine, pp.97-113, 2006. ,
Patch-Based Nonlocal Functional for Denoising Fluorescence Microscopy Image Sequences, IEEE Transactions on Medical Imaging, vol.29, issue.2, pp.442-454, 2010. ,
DOI : 10.1109/TMI.2009.2033991
URL : https://hal.archives-ouvertes.fr/inria-00541082
Statistical methods of analysis, 2003. ,
DOI : 10.1142/5224
Chapter 1 Basics of metrology and introduction to techniques Full-field measurements and identification in solid mechanics, pp.1-29, 2012. ,
Multiframe sure-let denoising of timelapse fluorescence microscopy images, 2008 5th IEEE International Symposium on Biomedical Imaging: From Nano to Macro, pp.149-152, 2008. ,
DOI : 10.1109/ISBI.2008.4540954
CCD noise removal in digital images, IEEE Transactions on Image Processing, vol.15, issue.9, pp.2676-2685, 2006. ,
DOI : 10.1109/TIP.2006.877363
Noise Measurement for Raw-Data of Digital Imaging Sensors by Automatic Segmentation of Nonuniform Targets, IEEE Sensors Journal, vol.7, issue.10, pp.1456-1461, 2007. ,
DOI : 10.1109/JSEN.2007.904864
Practical Poissonian-Gaussian Noise Modeling and Fitting for Single-Image Raw-Data, IEEE Transactions on Image Processing, vol.17, issue.10, pp.1737-1754, 2008. ,
DOI : 10.1109/TIP.2008.2001399
Using deconvolution to improve the metrological performance of the grid method, Optics and Lasers in Engineering, vol.51, issue.6, pp.716-734, 2013. ,
DOI : 10.1016/j.optlaseng.2013.01.009
Studying the Mechanical Behaviour of Asphalt Mixture with the Grid Method, Strain, vol.28, issue.1, pp.1-15, 2013. ,
DOI : 10.1111/str.12006
Invited Review Article: Measurement uncertainty of linear phase-stepping algorithms, Review of Scientific Instruments, vol.82, issue.6, p.61101, 2011. ,
DOI : 10.1063/1.3603452
Use of rigid-body motion for the investigation and estimation of the measurement errors related to digital image correlation technique, Optics and Lasers in Engineering, vol.46, issue.2, pp.185-196, 2008. ,
DOI : 10.1016/j.optlaseng.2007.05.008
Radiometric CCD camera calibration and noise estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.3, pp.267-276, 1994. ,
DOI : 10.1109/34.276126
Comparison of Local and Global Approaches to Digital Image Correlation, Experimental Mechanics, vol.39, issue.8, pp.1503-1519, 2012. ,
DOI : 10.1007/s11340-012-9603-7
URL : https://hal.archives-ouvertes.fr/hal-00750756
Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.46, issue.3, pp.423-441, 2011. ,
DOI : 10.1007/s11340-010-9450-3
Optimal Inversion of the Generalized Anscombe Transformation for Poisson-Gaussian Noise, IEEE Transactions on Image Processing, vol.22, issue.1, pp.91-103, 2013. ,
DOI : 10.1109/TIP.2012.2202675
A Wavelet Tour of Signal Processing, Third Edition: The Sparse Way, 2008. ,
Uncertainty on fringe projection technique: A Monte-Carlo-based approach, Optics and Lasers in Engineering, vol.51, issue.7, pp.840-847, 2013. ,
DOI : 10.1016/j.optlaseng.2013.01.023
URL : https://hal.archives-ouvertes.fr/hal-01024470
Image restoration with noise suppression using a multiresolution support, Astronomy and astrophysics, vol.112, pp.179-189, 1995. ,
Dynamic visual cryptography for optical control of vibration generation equipment, Optics and Lasers in Engineering, vol.50, issue.6, pp.869-876, 2012. ,
DOI : 10.1016/j.optlaseng.2012.01.013
PRODUCING AND TRANSFERRING LOW-SPATIAL-FREQUENCY GRIDS FOR MEASURING DISPLACEMENT FIELDS WITH MOIRE AND GRID METHODS, Experimental Techniques, vol.21, issue.5, pp.23-26, 2004. ,
DOI : 10.1007/BF02327139
IDENTIFICATION OF IN-PLANE VIBRATIONS USING TIME AVERAGE STOCHASTIC MOIRE, Experimental Techniques, vol.28, issue.4, pp.41-45, 2005. ,
DOI : 10.1007/BF02322141
Applicability of time-average moir?? techniques for chaotic oscillations, Physical Review E, vol.76, issue.3, p.36208, 2007. ,
DOI : 10.1103/PhysRevE.76.036208
Deconvolution of 3D fluorescence micrographs with automatic risk minimization, 2008 5th IEEE International Symposium on Biomedical Imaging: From Nano to Macro, pp.732-735, 2008. ,
DOI : 10.1109/ISBI.2008.4541100
A Study of the Influence of Calibration Uncertainty on the Global Uncertainty for Digital Image Correlation Using a Monte Carlo Approach, Experimental Mechanics, vol.4, issue.4, pp.1661-1680, 2013. ,
DOI : 10.1007/s11340-013-9746-1
Stress intensity factor measurements from digital image correlation: post-processing and integrated approaches, International Journal of Fracture, vol.40, issue.1, pp.141-157, 2006. ,
DOI : 10.1007/s10704-006-6631-2
URL : https://hal.archives-ouvertes.fr/hal-00013818
Enhancing with deconvolution the metrological performance of the grid method for in-plane strain measurement, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.1563-1567, 2013. ,
DOI : 10.1109/ICASSP.2013.6637914
URL : https://hal.archives-ouvertes.fr/hal-00804719
Sensor Noise Modeling by Stacking Pseudo-Periodic Grid Images Affected by Vibrations, IEEE Signal Processing Letters, vol.21, issue.4, pp.432-436, 2014. ,
DOI : 10.1109/LSP.2014.2304570
URL : https://hal.archives-ouvertes.fr/hal-00955709
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, pp.259-291, 2014. ,
DOI : 10.3934/ipi.2014.8.259
URL : https://hal.archives-ouvertes.fr/hal-00749804
Photomechanics, Topics in Applied Physic 77, chapter Fringe Analysis, pp.55-102, 2000. ,
Statistical Analysis of the Effect of Intensity Pattern Noise on the Displacement Measurement Precision of Digital Image Correlation Using Self-correlated Images, Experimental Mechanics, vol.43, issue.6, pp.41701-707, 2007. ,
DOI : 10.1007/s11340-006-9005-9
Quantitative Error Assessment in Pattern Matching: Effects of Intensity Pattern Noise, Interpolation, Strain and Image Contrast on Motion Measurements, Strain, vol.47, issue.2, pp.45160-178, 2009. ,
DOI : 10.1111/j.1475-1305.2008.00592.x
On Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.51, issue.4, pp.405-422, 2011. ,
DOI : 10.1007/s11340-010-9449-9
