Identification of an Optimal Derivatives Approximation by Variational Data Assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2010
Variational data assimilation technique applied to identification of optimal approximations of derivatives near boundary is discussed in frames of one-dimensional wave equation. Simplicity of the equation and of its numerical scheme allows us to discuss in detail as the development of the adjoint model and assimilation results. It is shown what kind of errors can be corrected by this control and how these errors are corrected. This study is carried out in view of using this control to identify optimal numerical schemes in coastal regions of ocean models.
assimbc1.pdf (495.08 Ko) Télécharger le fichier
hal-00938191 , version 2 (27-05-2009)
hal-00938191 , version 1 (29-01-2014)
Eugene Kazantsev. Identification of an Optimal Derivatives Approximation by Variational Data Assimilation. Journal of Computational Physics, 2010, 229 (2), pp.256-275. ⟨10.1016/j.jcp.2009.09.018⟩. ⟨hal-00938191v2⟩
420 Consultations
317 Téléchargements
